Sound Movement icon Sound Movement — Stereo mic sound localization triggers left/right scripts to control robot movement, enabling directional responses (turn/move) to audio. Try it →
Omnibot 2k Wheels
Omnibot 2K Wheels
Hey Guys,
I'm just starting off a new project after I got an Omnibot 2k off ebay. I'll be creating a project page for it soon, but I thought I'd share a little bit of it now.
When I dismantled the bot, and gave it a clean, I noticed that the wheels were pretty degraded. I know josh can create new ones, but being new to this, I really wanted to learn something new, so decided to make my own mould.
What I did then, was to carefully remove one of the existing tyres and then used a sealer to seal all the cracks.
I then setup a box for it, and also attached a kind of funnel to help pore in the ruber (turns out it wasn't that great, but you've gotta try these things:))
I then cast the hole thing in silicone
Finally, I then cast the tire and tada:)
I think it worked pretty well. The only bad bit is that I don't think I mixed the rubber to cast the tire very well as it's a little sticky. But hey, not bad for my first attempt:)
Hi Draken,
Sure do, checkout this post for a list of what I currently have https://synthiam.com/Community/Questions/2431&page=3 From the looks of it, I should have 1 set of 2000's and I have plenty of Jr's.
My email address is in the other post so drop me an email and let me know if / what you'd like.
Matt
#74
@ mike , the treads are rubber so the stretch. Just stretch them a bit and slide it over the edge of the hub. The lip is only a couple mm high.
