Pushover icon Pushover — Send robot status alerts to iOS, Android and Windows via Pushover.net. Configure User/App keys to notify on low battery, stuck or task events. Try it →
Noisy Camera Tracking
Guys, I just hooked up my camera. I hard wired the leads to the camera circuit board (confirmed to be working) and set up a camera tracking widget.
When I have no servo movement selected in the config, the camera seems to track my hand just fine, however, when I check off camera track and set my neck and head servos, the processed display fills with a LOT of tracking delta and it doesn't seem to clear up. The "head" goes a little bizzerk as it tries to rectify.
Here is the image...
P.S.
Messed around with sensitivity to no avail. It reduces noice, but still get overall screen of delta noise.
Lowering sensitivity and object size didn't change it?
Nope. Seems that the tracking is clear (no deltas) when it starts, however, as soon as there is some movement (I wave my hand), then the display goes bonkers like above.
Is it generally a matter of messing with size and sensitivity?
That's because you are using Motion tracking mode.:)
If your robot is physically set to move, you may want to use a tracking method other than "Motion". Because as you experienced, the robot will move and therefore the image moves
Motion Tracking is used when your robot is stationary to detect movement. You can also write a short little EZ-Script to sweep a camera mounted on a servo and speak when it detects motion. Here is an Example Project for you: Example-Script-CameraScanForMotion.EZB
Here is the EZ-Script:
$direction = 1
:START
  ControlCommand("Camera", CameraMotionTrackingDisable)
  if ($direction = 1)
    ServoUp(D6, 5)
  else
    ServoDown(D6, 5)
  if (GetServo(d6) > 80)
    $direction = 0
  elseif (GetServo(d6) < 20)
    $direction = 1
  sleep(500)
  ControlCommand("Camera", CameraMotionTrackingEnable)
  $count = 0
  :SCAN
    if ($count = 10)
      goto(START)
    if ($CameraIsTracking = 1)
      Say("I see you!")
      Halt()
    endif
    sleep(250)
    $count = $count + 1
  goto(SCAN)
or you may use the motion tracking for A stationary camera and make the robot move
Ah, ok. I think I get that. DJ although there are motion controls in place on the screen, the robot is not actually moving during this testing. Is that a factor in your determination?
