HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
What application would you see it being used for?
https://synthiam.com/Community/Questions/7029
Also, bumpers, or touch like button sensors only without the tactical feel. Kind of like tv's today. They dont have buttons so much as sensors that detect which spot on the tv was touched.
They could be used for bumpers. Really anything that you want to know has made contact with something else.
My use would be to know that the hand (or what part of the hand) has touched the object I am picking up.
Couldn't you do that with the ADC port? You don't need any additional hardware.
Try it - simply connect a bare wire to the adc port and let it float. Add an ADC Graph and watch what happens when you touch it.
You couldn't use it for bumpers, because objects around your home will not affect it. Think about your phone screen - what ever touches it needs to conductive
The thought for bumpers was to use conductive material like copper foil which would press against another conductive material, but that too could be done with analog I suppose. I'll give it a shot. Thanks.
Analog input is quite amazing! To create capacitive touch, you throw a very tiny capicator on the adc line.
Even without capacitors, you can do some pretty amazing stuff. Add the ADC Graph control and play with it:)
@DJ,
You really need to do more of those wonderful video tutorials, that inspire ideas. Not the spit polished ones, I miss the videos from your basement. ARC has come so far from those days and there are so many bells and whistles that I could definitely benefit from videos clips of new parts of ARC. Like a video library. I know you are busy running a big business, but maybe you could hand it off to one of the other fellas?! Everyone including those that are using it for STEM would benefit. I know I learn faster with videos than with written word.
That device on post #1 looks good if you need a lot of input but don't want to tie up 8 ADC ports. If you're not bound by those constraints then KISS and do what DJ suggests and it will be more simple to implement.
DJ (or someone who knows more electronics than me), can you explain in a little more detail how you hook this up? What does it mean to let the wire float? Are you just connecting the bare wire to the ADC signal port and nothing else? Where would the capacitor go and what do you mean by "small" (range of acceptable specs)?
Thinking about something like this on the ends of a gripper so if it grabs a person (or the cat) it wouldn't squeeze too hard.
