MMA7455 Accelerometer icon MMA7455 Accelerometer — I2C accelerometer for EZ-B robots, supplies IMU/acceleration data over the I2C interface. Try it →
Mobile App Continuous Toggle Button
I am working on a mobile app and have a button that I want to be able to toggle. First push would turn leds on and next push would turn leds off. This action should be repeated each time I push the button. The following script toggles button on then off but does not repeat these actions again. Here is the code:
#In Connect Script
$Pressed = 0
#Script for Mobile App Button
if (!$Pressed)
#High Beams On
Set (D17,ON)
Set (D19,ON)
Sleep (100)
$Pressed = 1
Else
#High Beams Off
Set (D17,OFF)
Set (D19,OFF)
Sleep (150)
$Pressed = 0
endif
The first time I push the button the lights come on and the second time I push the button the lights go off. This is good but any further pushes result in no action. I tried putting in a loop but still didn't work. Any thoughts would be appreciated. Rick :)
@DJ:
There is an EZ-Script bug:
script to reproduce the bug:
$pressed=false
$pressed=!$pressed
if ($pressed)
  #correct
  print("true")
else
  print("false")
endif
#generates:
#Error on line nn: Missing String Quotes or Invalid Expression at index 0: !
$pressed=!$pressed
if ($pressed)
  print("true")
else
  print("false")
endif
@Rbonari,
Change your code to:
if ($Pressed)
  # High Beams On
  Set(D17,ON)
  Set(D19,ON)
  $Pressed=0
ELSE
  # High Beams Off
  Set(D17,OFF)
  Set(D19,OFF)
  $Pressed=1
endif
Note: Spaces between Set and ( generates a parser error.
@PTP
Thanks much, I will give this a go. In my mobile app script I don't have a space between Set and ( but thanks for the reminder. Rick
Use the Blockly interface to learn how to use ez-script. Click on the word Blockly in this message to read about it. Do not put spaces between brackets and commands, that is not correct syntax. Please read the EZ-Script manual, examples are provided. Blockly also provides examples.
if ($pressed = true)
  set(D0, true)
  $pressed = false
else
  set(D0, false)
  $pressed = true
endif
@PTP
Thanks PTP, that works great. I have two other buttons that I want to do the same thing with but they don't work at all. I use the same exact code but different sets of leds but no go. I put the following code in the connect script for the second and third buttons:
$Pressed1=0
$Pressed2=0
Do I need to name these button variables with a unique name for each, other than Pressed? Thanks much...Rick
@PTP
Evidently it is invalid to have variables $Pressed, $Pressed1, etc. When I changed the variable names to $Pressed, $Highbeams and $Taillights all three buttons worked as advertised. Normally $Pressed, $Pressed1 and $Pressed2 would be considered valid variables. Any thoughts on this. This appears not to be the case with ez-script? Thanks again...Rick
@rbonari,
No problem with variables ending in numbers, must be something else.
Example project: test_buttons.EZB
  1. Start the init script
  2. press the buttons and listen the press state on your desktop speakers.
@PTP
Thanks PTP. I will give it a try and keep you posted....Rick
