Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Mobile App Continuous Toggle Button
I am working on a mobile app and have a button that I want to be able to toggle. First push would turn leds on and next push would turn leds off. This action should be repeated each time I push the button. The following script toggles button on then off but does not repeat these actions again. Here is the code:
#In Connect Script
$Pressed = 0
#Script for Mobile App Button
if (!$Pressed)
#High Beams On
Set (D17,ON)
Set (D19,ON)
Sleep (100)
$Pressed = 1
Else
#High Beams Off
Set (D17,OFF)
Set (D19,OFF)
Sleep (150)
$Pressed = 0
endif
The first time I push the button the lights come on and the second time I push the button the lights go off. This is good but any further pushes result in no action. I tried putting in a loop but still didn't work. Any thoughts would be appreciated. Rick :)
@PTP
I tried again and included $Pressed, $Pressed1 and $Pressed2 in my connection script and the three mobile app buttons are working. Not sure why it didn't work yesterday. I was wondering if it has something to do with the variables being initialized in the connection script rather than a startup script. What is the difference between connection startup script and a separate startup script. Seems that the connection startup script is the best way to go as the script is run automatically on connection. Your thoughts are appreciated....Rick
@PTP
How do I give you credit for answereing this thread? Thanks again....Rick
You can't... the thread is not a "require technical assistance" type thread. It is a plain conversation thread ...
@Richard
Thanks much for the clarification....Rick
