Update: I know I posted the question without good information of what I am attempting.
My final goal is to use Loomo to tow a UVC Rig that will use UVC lights to disinfect places. These UVC carts can be push around (manual version), or towed with Loomo (Autonomous). Loomos will be connected to Exosphere for routes to be completed every night when the places are closed.
Ok, What can I do?
Specs
Height x Length x Width 650mm x 310mm length x 570mm width Weight ~19kg (~42 lbs.) Max Payload 220 lbs Machine Parameters LCD Screen 4.3 inch, 480 * 800 pixels HD Camera 1080p 30Hz streaming with 104 degrees FOV 3D Camera Intel RealSense ZR300 Camera for depth-sensing & motion tracking Sensors Available Ultrasonic sensors, infrared distance sensors, touch sensors, encoders, IMUs Processor Intel Atom Z8750, 4 cores 2.56GHz, x86-64 Operating System Customized system based on Android 5.1 Memory 4GB Storage 64GB Battery Capacity 329Wh Motor Speed Limit 8km/h (4.3mph) in robot mode, 18km/h (11mph) in self-balancing vehicle mode Typical Range ~35km (22 miles) per charge Traversable Terrain Paved road and sidewalks, packed dirt, slopes < 15, obstacles < 0.4 inch (1cm), gaps < 1.2 inch (3cm) Features Mic Array 5 microphones enabling beamforming, voice localization and voice command recognition Waterproof IPX4
I think what we can do is whip up an Android app that runs on the device and converts it into an EZB - it exposes a TCP connection for ARC to connect to. This is similar to how the Ohmnilab telepresence robot or Raspberry Pi EZB Server works.
Sound like a Plan, Who can do this?
I noticed that your photo has a platform attached to the loomo. What is it and where did you get it
It’s a Loomo delivery platform we found on the web, we could not find it to buy so we are actually building it ourselves. Prototype will be ready this week.
Found this also Android Loomo ROS Core
This repo allows you to connect a Loomo robot to an host PC running ROS. It exposes a number of the Loomo's sensors to ROS in ways that are compatible with the ROS Navigation stack. https://github.com/skalldri/android_loomo_ros_core
I assume that because it is in the front it can move a good load. I tried to attach sometime at the back and it could not carry any load
