Ultrasonic Radar icon Ultrasonic Radar — Ultrasonic on a servo sweeps 180°; radar shows distances and obstacles, integrates with movement panels for automatic avoidance, scriptable GetPing Try it →
Long Life 7.4v Lipo Battery And Charger For Ez-b V4
Long Life 7.4V Lipo Battery And Charger For Ez-B V4
Hi everyone.
I need a little advice in regards to LiPo batteries for the EZ-B v4. I have been waiting for my dev kit, balance charger, 7.4 LiPo, and a few extras to be delivered for quite a while now, and after I sent of an email to the very helpful EZ Robot guys and gals inquiring what the delay was, it turns out that there is a shipping issue with sending loose batteries from China which has been holding up my order being sent. I have requested a refund for the LiPo and charger which has been honored, so no problems there.
So what I need the community's help with is advice on what I can safely use with the EZ-B v4. Can anyone recommend a good, reasonably priced LiPo battery pack that can hold a long charge, say about 2500 mAh or more that will work well with the v4, and a good charger to go with it? A balance or auto cut off charger would be preferred as I hear that LiPo batteries can be a bit finicky and care needs to be taken to avoid killing them.
Any advice or recommendations anyone can offer would be greatly appreciated.
Cheers,
Steve.
#25
Lipos and Li-Ion have basically zero battery memory effect and you can damage them by over discharging them... You can however, charge them any time you want.... NiMH have some memory effect, but very little... NiMH can benefit from the occasional deep discharge to regain some lost battery life. They can be charged at any time as well, even if just to top up... NiCad have the most memory effect... NiCads need to be fully discharged every time they are used before recharging....
#26
I could be wrong but DJ may have been referring to using rechargeable AA batteries vs standard alkaline AA if you go that route?
#27
Thanks for your replies guys. I've just ordered myself a balance charger and decided to go for the 5000 mAh LiPo battery Rich mentioned, which should be with me in a couple of days.
@Richard. Yes it is just the EZ-B and power shell I will be using, but when I mentioned using the barrel jack, I meant the stand alone jack that comes with the dev kit. Thanks for pointing me in the right direction. :)
@jdebay. Thanks for the photo. That's what I had in mind, so thanks for confirming. ;)
Steve.
#28
@Steve.... sorry, the stand alone barrel jack is what I meant.... You can use it with your 5000mAh lipo no problem......
#29
No problem. Thanks Richard. :)
#30
@Richard Thanks for clearing that up for me.:)
@Zap Yes I am in fact talking about the AA's;)
#31
Hi everyone
I have just bought this "bad boy" which is a Venom LiPo 2S 7.4V 10,000mAh 35C. I am pretty confident that I can just connect it up to my roli and it will work fine but can anyone confirm this?
Also can anyone advise of the best setting to charge it? My lipo charger will charge up to 5 amps.
And can I also presume that the low voltage warnings on the EZB will continue to work when a higher rated battery is used?
Thanks for any advice - I would prefer to be on the right track before connecting.
Regards
Chris
#32
@ZebraStripes Yep... plug and play dude.... With that battery I am pretty sure Roli could drive across the outback on one charge....:P
Your charger should work too. However being a very large capacity battery it will take much longer to charge.... If it were me (and I am not knocking ez robot's lipo charger) I would grab a better lipo charger off of eBay...
Remember amps are "pulled" by a device not "pushed" into it by the battery... What you have effectively done is buy a bigger gas tank for Roli... Roli is still going to draw the same amount of power it did with it's original battery, however now with the larger capacity battery it will have a much longer runtime...
