Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Hello I'm currently buying parts for an EZ-B project but I am not sure if the LCD screen I want is compatible. If someone could help me out it would be very much appreciated. :) The LCD Screen
That LCD will work great! The UART mode will be a fantastic and easy method. You'll need a three wire servo cable. I purchase them in bulk off eBay. Here is a link..
eBay servo Extension Cables
I usually buy 300 mm wires in bulks of 10 for $2-$3 with free shipping.
Thank you so much!!! Ill be sure to post pictures and explain it once I finish it and one quick weird question do you think it woiuld be cool if I use the body of a 2-XL???:) :) :)
Which 2-XL version? I think they are both pretty cool:)
I was thinking the older one. More of a classic. lol :P
#15
Alright just found a Classic "Type 2" 2-XL on Ebay for a fair price for only using the shell!!!! SOLD!!! :) :) :)
#16
I just bought one of these LCDs and have NO CLUE whatsoever how to connect it to the EZ-B.
https://www.microtivity.com/p/IM161/lcd-module-1602-white-on-blue-with-backlight
It has 16 pins in the "standard 1602A" configuration. I think I'm supposed to do the following:
  1. Plug in a cable to one of the digital ports on the EZ-B
  2. Solder the Ground to Pin 1
  3. Solder the Positive to Pin 2
  4. Solder the Signal to Pin 5
Optionally, I can plug in another cable to another digital port and solder the Positive and Ground to Pins 15 and 16, respectively to power the backlighting.
Do I just ignore the other pins? What about Pin 3? It's labeled "Contrast Adjust". How do I adjust the contrast if required?
Thanks!
