Myo Gesture Armband icon Myo Gesture Armband — Map Myo armband gestures and accelerometer to servos and ARC scripts for arm-mimic control; supports multiple armbands. Try it →
It appears that LCD in the link does not have a serial or I2C communication controller. You may be able to get it to work with digital i/o (but that would require a lot of wires and complicated programming). If you would like to connect an LCD to the EZ-B, I recommend a Serial LCD.
Clickity Click
A serial LCD operates using a 1 wire connection. The EZ-B transmits "serial data" over a "baud rate" to the LCD by one of it's I/O pins. The baud rate is usually 9600, or higher.
Norway
Thank you for reply.
How can I control the LCD connected to the Ez-b with Csharp? Do you have any code samples?
Sorry for "too many questions" but this project is really interesting! :D Thank you!
  • Mix3rn
I don't think there are any code samples in the SDK specifically for LCD control and unfortunately I don't have a serial LCD to play with, otherwise I'd give you a hand...
That being said, I'd start by downloading and modifying the following code to suit your needs: Simple Scott Edwards Serial Backpack LCD Class and Example
I'm not sure how heavily the code will need to be modified (aside from adding the EZ-B connection) but the LCD you purchase should at least include documentation on the command structure to get you started...
Hi,This is Alina from Tsingtek Display Co.,Ltd . We are one of professional LCD ,LCD module ,OLED manufacturers from mainland China .Yes ,I completely agree with radmeck that the supplier should provide the detail datasheet ,and also programming if you need it also :D . I found what you need is just 8X2 character LCM ,for character LCM,only few people would like to choose serial ones .
But I can provide you some technical information .My email address : [email protected]
I'll be more than happy to help you in anyway we can
Best Regards Alina
Norway
Hello, thank you for your time! I found an lcd screen in a computer to a friend (he gave it to me) This one
It has an internal usb connector (4 pin) It's usual usb, so I guess its power, ground, and two signal cables?
But how to connect the cables to the Ez-B ? confused
Again, thank you!
  • Mix3rn
That LCD is a USB. The connections to the EZ-B are either Serial (uart/rs232) or I2C.
Check this link for compatible LCD modules with the EZ-B: Clickity
Once you have the LCD module that is compatible with the EZ-B, check the TellyMate or Uart library for transmitting data to it. There are a few Tellymate examples in the EZ-SDK Package.
Optionally, if you are using the ARC software... You can easily write to serial by using the SendSerial() command...
SendSerial(d1, 9600, "Hello, this is some text)
Mix3rn, I'm in a similar situation trying to interface my USB rocket launcher/webcam with the EZ-B. Since you can't connect (USB) directly you basically need to hire a translator so they can communicate. Perhaps a little something' like this:
(1) Download and install LCD Smartie to interface with your USB LCD.
(2) Create scripted events in ARC that fire off LCD Smartie commands to control the LCD ouput.
If this sounds like too much work or you absolutely need native control through the EZ-B you'll need to bite the bullet and purchase a serial or I2C LCD.
Hope this helps...
P.S. It takes some time to get your head around the EZ-B paradigm if you're used to a PC-centric computing model. My 2 cents...
https://www.dwin.com.cn/en/ DWIN 24-bit colored HMI kernel was put into production in August, 2010. It has won the market's affirmation because of its outstanding performance, functions and low cost. 24-bit colored HMI drove by H600 kernel is replacing the elder 16-bit colored HMI rapidly and become the better graphical interface of our customers' products. DWIN 24-bit colored HMI based on H600 kernel now covers all the sizes from 5.0 inches with a resolution of 800x480 and 18.5 inches with a resolution of 1365x768, our product line covers the consuming class(C series) to automobile class(Q series) to meet the needs of different customers. [u]Excellent performance on colors Improve the display speed substantially Any-angle rotation by software Enhanced and optimized GUI decreases the effort and difficulty for further development. Greatly raise the value for clients by systematic supply management [/u] DWIN can supply low priced 24-bit color HMI with better quality than other European products. Even compared with the Industrial class Non-drivered LCD made in Japan, Korea and Taiwan, the advantages of DWIN's products are obvious. With the information revolution and social progress, traditional LCD is too monotonous and inflexible to meet the demands from customers. DWIN is the best solution for making a better interface for your product you never seen before! https://www.dwin.com.cn/en/
