Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Ah, that's an easy one - you need to Calibrate your servos...:)
When you first loaded ARC, it asked if you wanted to view the Courses to follow the Lessons. You must have accidently pressed DO NOT SHOW AGAIN and the NO button. The Course page can be found under the LEARN button on the website - it's quite easy to find. You will find it on the top menu bar of this website. Press LEARN and now you have some courses and lessons:D
I recommend you read each lesson - however, the ones that are most relevant to you are...
Also, have you verified that the servos are connected to the correct connections on the EZ-B v4? The assembly tutorial might be of help as well
Do not forget to follow the Connecting to JD as well.
Your video is marked private... can't watch it...
salderson, can you confirm that you have read my last reply? Your most recent reply has only the words "jd gripper" in the message. I believe you might have clicked the POST button accidentally.
Let me know if you have read my previous message and we will get things running for you:)
I'm just resurrecting this thread a bit. It's hard for me to contribute since I don't have my stuff yet but I didn't hear that servo power up at all. It seems like either it's plugged in incorrectly or it's a bad servo.
@Zap nailed it I think. The servo doesn't move when plugged in or when the power was cycled on the EZ-B. Both times it should have moved at least a little.
If looks like it was connected correctly therefore it may be a dead servo. When you set all servos ports to 90 and connect the gripper can you open and close the gripper? Don't put much force on it, if it starts to buzz stop forcing it. If it freely moves (like it did when you opened it in the video) the servo is either not connected properly or it is dead.
If that's the case, make sure you have it connected the correct way around (black to black, white to red and white to white). If you have then the servo is dead.
If the servo is dead use the Contact Us page to file a warranty claim and include a link to this topic. EZ-Robot will sort out a replacement servo and explain what you need to do.
#15
Hey guys,
Just wanted to let you know that our Micro servo actually changed over to digital electronics and won't move when powered up, only when a signal is sent. Also wanted to mention that from values of 0-20 there is a dead zone, but it doesn't really matter as you wouldn't want the grippers to open that far anyway.
@Salderson I couldn't tell if you hit the 90 degree button or not at the end of the video, if you did and the servo still isn't working please Contact Us
#16
Has anyone come across this problem
