I would like to confirm if this is proper behavior or a bug.
After many hours of testing I have come to believe that the following Javascript command to release all servos on EZB board #2 also shuts down Uart 1 and 2.
Servo.releaseAll(2);
The fact that my Kangaroo motor controllers attached to Uart 1 and 2 on my #2 EZB will not respond after running certain scripts has been driving me crazy. It took me a lot of troubleshooting hours of trying almost every combination of tricks I could think of then having to restart the robot each time until I finally stumbled across that removing the above command keeps the mentioned Uarts alive.
If this is normal behavior? I would understand it being so as these Uarts are connected through the same digital pins that servos can use. If so, perhaps a mention in the manual or the API help section would be helpful and save someone a lot of time. Maybe I just missed it if it is.
At the very least this journey in troubleshooting these scripts for the reason my Uarts would stop to respond has really aided me in learning Javascript! LOL.
Thanks in advance!
Indeed, you're on the right track with your thinking, Dave. If you want to release a specific subset of servo ports without affecting others (such as UART ports), you can indeed write a JavaScript snippet to selectively release only the servos you're interested in. This approach allows you to avoid the unintended side effects of using
Servo.releaseAll()which, as you've discovered, can impact other functionalities tied to the digital pins.Here's an example of how you might write such a script in JavaScript to release a specific set of servo ports:
In this script,
servoPortsToReleaseis an array containing the ports of the servos you wish to release. TheforEachloop iterates over this array, and for each port number in the array, it callsServo.release(port, 2);to release that specific servo on EZ-B board #2.This method gives you fine-grained control over which servos are released, allowing you to preserve the state of your UARTs or any other functionalities you don't want to be affected.
Remember, the second parameter in
Servo.release(port, 2);specifies the EZ-B board index, so adjust it according to which board you're working with.
