Full Screen Video Player icon Full Screen Video Player — Fullscreen overlay video player controlled by ControlCommand: play/pause/resume/stop; ESC cancels playback and locks new playback until unpaused. Try it →
Twitter
JSON to mjbots quad robot series
JSON To Mjbots Quad Robot Series
My robot wants to communicate via JSON commands (it is controlled via JSON from a browser) but I need to use ARC to talk to it. It also sends a lot of data back over JSON to provide current servo status that would need to be fed back into ARC.  Any thoughts if this can be adapted to communicate with the robot? https://github.com/mjbots/quad/blob/main/mech/web_control_assets/index.html
Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors
Websocket Client by Synthiam
WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status.
Twitter
#17
Robot just stood up  WOOT!   So happy.
#18   — Edited
Noice!!!!
Once you figure out the movement commands and speed, then you can use the Custom Movement Panel to rock it
Something like this for Forward. I dunno if that's the correct json or not. But the idea is use the Map function to convert the ARC speed (0-255) into a float of (0-1) for that robot.
var s = Utility.map(
  Movement.getSpeed(),
  0,
  255,
  0,
  0.5);
ControlCommand("WebSocket Client", "Send", "{\"command\":{\"mode\":\"walk\",\"log\":\"disable\",\"v_R\":[" + s + ",0,0],\"w_R\":[0,0,0],\"walk\":{\"step_height\":1,\"maximize_flight\":false}}}");
Twitter
#19   — Edited
Thanks for all your help on this DJ.  I have it obeying a bunch of commands.  Still a while to go but he can stand laydown and we are learning to walk.  Lots of fun.
