Auto Release icon Auto Release — Auto-release servos after inactivity: set EZB board/ports, choose 1-60s delay, add/remove ports, pause and view status. Try it →
Resolved Resolved by Athena!
I noticed that on the Talk servo 2, the "invert direction" does not work, it just stops the servo dead.
Has anyone noticed this?
Figures it out, invert direction has to be less than 90.
EzAng
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Talk Servo V2 by Synthiam
Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop.
solved it, hast to be less than 90
Actually you discovered a bug - I just fixed it for ya cause i was curious about it. I'm going to push an update for Early Access because it's a minor easy fix.
#3   — Edited
I thought so,
I figured a work around - under 90
Great, thanks Dj, all my best
Thanks again, I downloaded it already
My ARC says  2021.12.27.00
