Arduinocoms icon Arduinocoms — EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control Try it →
hello Master D...
i would like to buy EZ-AI 2 component cost $58.95? where the store to click payment? is it same store with ez-robot? now, i have found the program i've looking for. so for make real like ur teddy for ur grand daughter, i think its good to speak about weather and can sing as well.... i can modify later... please guide again, thanks
There are many ways to make parts. 3D printing is one way which is the most common for home robot builders. Some use PVC scraps and shape them with heat. Some use cardboard. Some use metal and cut and shape it. Some use fiberglass. I have seen some on here use wood. There are many ways to build structure.
I have a website that has a page that I have gathered some general information about topics that relate to robotics.
https://cochranrobotics.com/Student-Resources
Feel free to look there for information. I am sure that these links will take you to websites that have more information in it.
To answer you question, if you buy the JD head and nothing else, you will be missing the EZB robot controller. This is the brain of the robot so that should definately be purchased. You will also need a battery and a battery adaptor to fit the base that the EZB robot controller sits in.
You will need to download the ARC software to a windows based computer that is running windows 7 or greater.
After that, you plug everything into the EZB correctly (see EZ-Robot LEARN section of this website).
You connect your EZB to your network (again instructions are in the LEARN section of the website) over wifi.
you connect ARC to your EZB. Once this connection is made, you can program ARC to do whatever you want your robot to do.
The JD head has a camera, 18 lights for the eyes and 2 servos in the neck for pan and tilt. How you attach this to your robot body could be as easy as using hot glue. It could be as complicated as fabricating some new attachment. It really becomes up to you at this point.
Speech recognition, object recognition, and everything else you have asked about is available in ARC. I would recommend that you download ARC (free download) and install it. You dont need a robot to be able to see what all the software can do. I had the software installed for 3 or 4 months prior to ever having a EZ-B which allowed me to learn it pretty well. I would recommend that you start with this to see what is available in ARC. Once you see what is possible you will be able to know if it is right for what you want to do.
hello Master D...
cz im from indonesia, need all by shipping cost with very expensive, please let me know if there is need more to buy. here is my list
  1. personal roborealm program
  2. robot part 2.1. JD Humanoid 1 set 2.2. Lipo Battery = 2 pcs 2.3. EX B-V4 Developer kit 2.4. lipo Battery Balancer Charger 2.5. Power Shell 2.6. Alternate Power Adapter 2.7. 6xAA Battery Holder 2.8. Inline 5V regulator (30cm) = need how many pcs? 2.9. 18 RGB LED PCB 2.10. Heavy Duty servo = need how many unit? 2.11. Standard Micro servo = need how many unit? 2.12. continuous rotation servo = need how many unit? cz i seen ur video for neck there was 3 unit 2.13. 2.5 amp motor controller = need how many unit? 2.14. jumper cable kit = need how many unit? 2.15. EZ-B-V4 Camera Cable (25cm) 2.16. EZ-B-V4 12C peripheral cable 2.17. Humanoid body includes battery 2.18. Extension Block 10 unit 2.19. 4-in-1 orientation sensor 2.20. Inverted pendulum 2.21. ultrasonic distance
  3. robot componen part 3.1. Double Din Lilliput 669GL-70NP/C/T 3.2. QQ-Tech trademark Newest Mini Wireless Bluetooth Keyboard 3.3. ARCTIC S111 USB-Powered 3.4. Crucial Ballistix Sport 16GB Kit (8GBx2) DDR3 1600 MT/s (PC3-12800) CL9 @1.5V UDIMM 240-Pin Memory BLS2KIT8G3D1609DS1S00 3.5.Intel Core i5-4690K Processor 3.5 GHz LGA 1150 BX80646I54690K 3.6. 2 of Logitech HD Pro Webcam C920, 1080p Widescreen Video Calling and Recording 3.7. 2 of Hercules HD Twist cameras 3.8.EVGA Z97 Stinger Wi-Fi LGA 1150 Mini-ITX 2 DIMM Dual-Channel DDR3 2666MHz Motherboard 3.9. Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2). 3.10. Arctic Silver 5 Thermal Compound 3.5 Grams 3.11.SABRENT 2.5 to 3.5 Inches Internal Hard Disk Drive Mounting Kit (BK-HDDH) 3.12. 3 of Monoprice 104958 8-Feet 28AWG High Speed HDMI Cable with Ferrite Cores - Black 3.13. Samsung 850 EVO 250GB 2.5-Inch SATA III SSD 3.14. Seagate 4GB hard drive 3.15. Garmin GPS 18x Receiver 3.16. windows 8.1 64 bit
  4. power 4.1. 6 of Blue Sea Systems 10 Gang Common 150A Busbar with Cover 4.2.Power Bright PW400-12 Power Inverter 400 Watt 12 Volt DC To 110 Volt AC 4.3.NOCO Genius G15000 12V/24V 15A Pro Series UltraSafe Smart Battery Charger 4.4. 2 of SMAKN trademark DC/DC Converter 12V/24V/36V 11-40V Step Down to 6V/25A 6V 25A 150W Power Supply Module 4.5. 2 of SMAKN trademark DC/DC Converter 12V/24V/36V 11-40V Step Down to 5V/10A 5V 10A 50W Power Supply Module 4.6. Jazzy Select Elite Wheelchair U1 replacement battery - SPS Brand ( 2 pack - 12V 35Ah) 4.7. Wire Cord, 25', 10 Gauge, 4 Conductor (10/4) 600V SOOW
  5. robot controller 5.1. 5 x EZ-B V4s (120 Digital ports, 40 analog ports, 5 V4 cameras, 15 UART ports and 15 I2C ports) = need 5 unit? 5.2. 2x standar micro servo 5.3. 3 Arduino Min Pro 5V - 1 for parking sensors, 1 for neopixel in waist and one for neopixel in the head (dont understand)
  6. servo motor 6.1. 5bosch 12V servo? can apply with what brand? 6.2. 10HB-805BB Servos ? pls apply picture, i cant found it 6.3. 10HK 15298B Servos 6.4. DS929HV Servos ? not found it 6.5. 4MG996R servos
  7. other 7.1. 4 Parking Sensors LED Display Car Reverse Backup Radar System - Car distance sensor thread 7.2. Neopixel 16 led ring - NeoPixel thread 7.3. 4 HDMI cable breakout boards
question
  1. robot component part + power + servo and other things. what for? apply on which part?
  2. the servo its analog or digital?
  3. if i order item no 1 & 2, can i apply with other product? how?
  4. your ez-robot operation with what system?
please guide, thanks
There is a guy on who builds amazing parts from scraps on here named @EricEZ. He might be able to help as he speeds the same language ad you.
The parts you will need depend on what you want to build. All of the parts you listed were from multiple robot builds. You should either spend some time designing a robot to identify all of the parts you will need, or pickup the developer kit, battery and charger and see what you can build out of it. Don't start with a huge project. Start with something small and build from there.
