Hello ,
I am experiencing inconsistent UART data transfer from the EZ-B v4 to an Arduino Mega 2560. Single-byte transfers are very consistent between these two devices, but when I attempt to transfer 8 bytes, the reliability decreases significantly. I have attached samples of JavaScript and C++ code that I am using. Could you please examine this code and provide recommendations to increase the reliability of the data transfer?
Thank you very much.
Jack
JavaScript Code:
UART.initHardwareUart(0, 9600, 0);
sleep(10);
var pathTotalDistance = getVar("$pathTotalDistance");
var pathEndpointDistance = getVar("$pathEndpointDistance");
var oppositeDistance = getVar("$oppositeDistance");
var actualCourse = getVar("$actualCourse");
var desiredCourse = getVar("$desiredCourse");
var highByte = (pathTotalDistance >> 8) & 0xFF;
var lowByte = pathTotalDistance & 0xFF;
UART.hardwareUartWrite(0, [highByte, lowByte]);
print("Sending pathTotalDistance high byte: " + (pathTotalDistance >> 8));
print("Sending pathTotalDistance low byte: " + (pathTotalDistance & 0xFF));
print("pathTotalDistance: " + pathTotalDistance);
var highByte = (pathEndpointDistance >> 8) & 0xFF;
var lowByte = pathEndpointDistance & 0xFF;
print("Sending pathEndpointDistance high byte: " + (pathEndpointDistance >> 8));
print("Sending pathEndpointDistance low byte: " + (pathEndpointDistance & 0xFF));
print("pathEndpointDistance: " + pathEndpointDistance);
var highByte = (oppositeDistance >> 8) & 0xFF;
var lowByte = oppositeDistance & 0xFF;
print("Sending oppositeDistance high byte: " + (oppositeDistance >> 8));
print("Sending oppositeDistance low byte: " + (oppositeDistance & 0xFF));
print("oppositeDistance: " + oppositeDistance);
UART.hardwareUartWrite(0, [actualCourse]); // Send as one byte
UART.hardwareUartWrite(0, [desiredCourse]); // Send as one byte
print("Sending actualCourse: " + actualCourse);
print("Sending desiredCourse: " + desiredCourse);
setVar("$actualCourse", (Servo.GetPosition(17)));
halt();
C++ Code:
long pathTotalDistance = 0;
long adjacentRemainingDistance = 0;
long pathEndpointDistance = 0;
float oppositeDistance = 0;
float desiredCourse;
long actualCourse;
float diffCourse = 0;
float lastDiff = 100;
int lastIncomingByte;
int run = 0;
void setup() {
Serial3.begin(9600); // Communication with EZ-B
Serial.begin(9600); // Debugging via Serial Monitor
void loop() {
if (run == 0) { // State of RUN when the robot has yet to begin movement towards the reflector.
if (Serial3.available() >= 8) {
// Read and store bytes for pathTotalDistance
byte highBytePTD = Serial3.read();
byte lowBytePTD = Serial3.read();
pathTotalDistance = (highBytePTD << 8) | lowBytePTD;
// Read and store bytes for pathEndpointDistance
byte highBytePED = Serial3.read();
byte lowBytePED = Serial3.read();
pathEndpointDistance = (highBytePED << 8) | lowBytePED;
// Read and store bytes for oppositeDistance
byte highByteOD = Serial3.read();
byte lowByteOD = Serial3.read();
oppositeDistance = (highByteOD << 8) | lowByteOD;
actualCourse = Serial3.read(); // Read and store actualCourse
desiredCourse = Serial3.read(); // Read and store desiredCourse
// Print the above received parameters
Serial.print("pathTotalDistance: ");
Serial.println(pathTotalDistance);
Serial.print("pathEndpointDistance: ");
Serial.println(pathEndpointDistance);
Serial.print("oppositeDistance: ");
Serial.println(oppositeDistance);
Serial.print("actualCourse: ");
Serial.println(actualCourse);
Serial.print("desiredCourse: ");
Serial.println(desiredCourse);
delay(10);
// run = 1;
I look forward to your insights on improving the reliability of this data transfer process.
Hello Jack,Great question!You're correct in noting that flushing the buffer before checking for available bytes could inadvertently remove data you want to read. Let's clarify how to use buffer flushing effectively.
Understanding Buffer Flushing:
Correct Usage in Your Context:
Example of Proper Buffer Flushing:
Here's how you might incorporate buffer flushing only when necessary:
Key Points:
By using buffer flushing judiciously, you can maintain the integrity of your data while still managing errors effectively. If you have more questions or need further clarification, feel free to ask!
