Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
Idea: It Would Be Nice To Have Ocr
Just a thought. It would be nice for us to be able to read text from the camera. I am sure that would be very hard, however. But, just a thought . . . . in case it is just a hop skip and a jump from Glyph reading.
Also, the ADC ports have a meter for my temperature sensor. It shows up on the meter. It would be nice to have degrees F and C labels on it.
I just hooked up my PIR and it is working GREAT. I have completely tore down my Marty robot and completely rebuilt her. She is sort of the same as before but, I have the notebook in a location where I can do tel-presence. But the main thing I did was graduate to thicker servo extension cables.
I am in the process of navigation which I could never do before because of those cheap cables made the sensors unreliable. Now, I have a second chance at Navigation.
wish me luck! . . . . .
Mel
Spain
May luck be with you!:)
Thank You or Gracious or however you say it.
:D
You should post progress and vids of your build mel. I dont want to be one of the only robot fanatics posting updates;)
I will see what I can do. I made perfect arms and grippers only to find that they touched the floor when in the down position. Crazy! I never did that when I was young. Little AGE related stuff. I will have pix soon, I hope.
As far as Videos, wish me luck. I have an apartment so small we have to back up to turn around. It is an old age high rise. Navigation is the ONLY problem that I haven't mastered yet. But since the rebuild, I have solved the problem with the sonars, I think. I now have to reprogram everything.
Touched the floor? Thats great so it could pick stuff up:p
@movieMaker, press the CONFIG button on the Read ADC control and you can add a unit title and multiplier to display any unit:)
Thank You, my friend!
But, I don't Exactly know what the multiplier would be. But, maybe I could experiment.
@Josh
I meant the hand would not go down without hitting on the floor. Too dangerous to keep on the robot, so, I had to shorten them.
:D :D
@DJ With regards to the title and multiplier (been there done that), how does one change or get rid of the N/A that shows up as well?
@MovieMaker it is a big mathematical question between the ADC voltage (0-5v) and the scale of the data you want... I do not like math stress so I compared with data from another source (in my case a multimeter) and tweeked the multiplier until the results matched:P
