NMS Navigation Data Grabber icon NMS Navigation Data Grabber — Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan. Try it →
Resolved Resolved by CardboardHacker!
I Powered Up And Tried To Use The Movement Panel And Nothing Worked As Far As Th
I now have the ezb v3 connected via bluetooth. Now , I made my Movement Panel and setup for D14-D11. I hooked the red and black cable to the voltage from ex power.
I powered up and tried to use the Movement Panel and nothing worked as far as the movement panel. I have power and four wires. How should I handle this problem?
#25
Thank You, Maze.
I have got to take a quick break. My EZB just went out and got very hot. I may have to graduate to the V4. I am sure that you gave me the right answer, so I am awarding you the credit.
Thanks for your help. I will probably make another thread if I come up with a problem. If no problems then I will post results to this thread.
#26
@Mel Please stopping making threads of the same thing... Just use this one...
#27
I will do my best for you. This one is ended because my second V3 went out. I found out what was happening. I had only the signal wire plugged into the digital ports. The plastic was sticking out. It bent the +5vdc line onto ground. I had a little trouble plugging it in because my printed case was not completely straight on the place you plugged in. (all my fault)
I am sure that I can use this info obtained. I will start a new thread on the V4. It will be almost from scratch put back together. See you there.
