Pandorabot AIML2 icon Pandorabot AIML2 — Connect ARC to Pandorabots AIML2 to run AI-driven virtual personalities for human-like text or voice chat, using API keys and script hooks. Try it →
Take all these screws out. Once they are out you can take it apart. You may be able to search YouTube for a video.
Depending on what walle it is. I had the same problem. There was a secret screw through the front of the main wheel. Depending when it was made there are 2 different materials of caps covering the screw. One is a hard rubber and one is glued on plastic. If it is the plastic one you'll have to drill a small hole to get at the screw.
I know there is a thread here that explains this with pictures...
I had the same trouble at first, then i just drill a hole right in the center of the wheel to reveal the hidden screw.
I have an U-command wall-e and I dont know if i should just try to pull the gearbox off
Listen to what Louis said. In the "Big" wheel, there is a screw. Drill a small hole in the center of the "hub" and stick a small phillips driver in there and give a turn until it grabs. If the whole is small, the screw won't come all the way out, but will disengage from the hub, and you can slide the assembly off.
@cyberdude Which side? One side has the gearbox and the other is the part that everyone looks at.
@cyberdude Thanks! I sripped the screw a little but i can overly drill it and get it out
