Sabertooth Movement Panel icon Sabertooth Movement Panel Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
Hugging Face Model Not Supported
I have a question about the ARC "Hugging Face" Robot Skill.
I set up the API as instructed. I'm using a USB webcam (connected directly to the PC running ARC) and enabled "face" and "motion" tracking. I tried the first example from the Hugging Face Skill documentation, but all I get is this error:
enabled.","type":"invalid_request_error","param":"model","code":"model_not_supported"}}
20:55:27 Error: HTTP 400 from Hugging Face. {"error":{"message":"The requested model 'Qwen/Qwen2.5-VL-7B-Instruct' is not supported by any provider you have enabled.","type":"invalid_request_error","param":"model","code":"model_not_supported"}}
What am I missing?
EZ-B v4/2 robot controller: dual Cortex ARM, Wi-Fi, audio/video, 24 servo/digital ports, I2C/UART, camera and Synthiam ARC control for custom robots
Hugging Face by Hugging Face Inc
Connects your robot camera to Hugging Face AI models for vision chat, object tracking, classification, captioning, and autonomous movement.
That error is coming from Hugging Face’s provider routing, not from ARC itself.
What it means
Qwen/Qwen2.5-VL-7B-Instruct is a vision-language model, and Hugging Face is saying:
"You don’t currently have any enabled provider that can serve this model."
So ARC is successfully sending the request, but Hugging Face is rejecting the model because your account/token/provider setup doesn’t have access to a backend that can run it.
What to check
1) Verify the model supports the task you chose
In the Hugging Face skill configuration, make sure you’re using the correct task:
  • Vision Chat for asking the model to see and respond
  • Object Detection for finding faces/objects in the image
  • Image Classification for labeling the whole image
  • Image Captioning for describing the scene
If you enabled face and motion tracking, that sounds more like Object Detection, not Vision Chat.
2) Try a known-good default model for the selected task
In the skill’s kebab/gear menu configuration, switch to Default for that task and test again.
For example:
  • Object Detection: facebook/detr-resnet-50
  • Image Captioning: Salesforce/blip-image-captioning-large
These are generally easier to get working than a large vision-chat model.
3) Check Hugging Face model access / provider availability
That specific error usually means one of these:
  • Your token is valid, but the model is not available on the enabled provider
  • The model may require a different provider than the one currently enabled in your Hugging Face account
  • You may need to select a different model that is supported by serverless inference
Hugging Face has a support article for model-based robot use in ARC here:
Important note about your webcam
Your USB webcam on the PC is fine. ARC can use that with the Camera Device skill. The webcam is not the issue here.
Make sure you have:
  1. Camera Device skill added
  2. Webcam selected in that skill
  3. Camera skill started
  4. Hugging Face skill configured to use that camera feed
If the camera is not running, Hugging Face would usually complain about no active camera, not model support.
Best next step
Try this:
  1. Open the Hugging Face skill settings
  2. Switch to Object Detection
  3. Use the default detection model
  4. Press Save
  5. Run Query Now
If that works, then the issue is specifically the Qwen vision-chat model/provider combo.
If you want Vision Chat
If your goal is the "robot sees and talks" behavior, you may need to:
  • choose a different vision model that your enabled provider supports, or
  • use a Hugging Face Inference Endpoint / compatible provider that supports that model
Quick question
Are you trying to do:
  • face detection / tracking, or
  • vision chat where the model describes the scene and answers questions?
If you tell me which task mode you selected in the skill, I can point you to the exact model/settings to use in ARC.
