Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
#1   — Edited
@DJ, can you use the arduino mega with a neopixel ring without using an EZB?
thank in advance  cheers
Ideally it would make sense to add neopixel capability directly to the mega firmware. I believe the neopixel robot skill uses a secondary arduino due to the timing required.
so I think you’d need the second arduino no matter what because the servos and pwm use the timers.
so ya, just use the robot skill I guess. I’ve never had good success with those neo pixels before. Not sure why lol
@DJ,
so if I use an arduino uno for the neopixel ring. I would then connect the uno to the arduino mega using the digital port of the servo port?
Thanks again for your fast response. As Dave has said be for, you Canadians are the best neighbors!
Cheers!
I got my only uno working but it will make the arduino mega disconnect. I’m not sure if it’s my uno so I ordered a new one.  Once I receive it I will check if it still makes my mega disconnect, hopefully not.  I’ll let you know.
Thanks again DJ.
merne
@DJ,
I got my Arduino uno in and programed it using David Cochran's tutorial.  I now have to use the USB cable or while running neopixel codes/commands.  Fun thing is I do not have to do this before.  I would just use the 5Volt step down connected to the uno  and the codes used to work.  I don't remember which Arduino script I used before my first Arduino uno broke.   But at lest it is now working.:)
I have not used the KEYESTUDIO 5V Pro Micro, I did order a Arduino Pro mini which I will try and see if I do not need the USB cable plugged in.
If any other member has any suggestions as to why I now need the USB cable so the neopixle ring does not lockup without using the USB cable that would be great
Thanks again @DJ for all your help!
PS I am not resolving this until maybe someone else know why this now needs the USB cable to work.
Here are some links from David Cochran...
https://synthiam.com/Community/Tutorials/NeoPixel-Ring-with-Arduino-as-control-board-16275
https://synthiam.com/Support/Skills/Misc/Neopixel-Ring?id=16158
https://synthiam.com/Community/Questions/Help-Connecting-A-Neopixel-Ring-2512
@DJ,
After looking at my wiring, I found the 5V input was not connecting do to a bad wire.  After replacing that wire the neopixel rings now work without having the USB cable connected.  Sorry for all the posts.  If you like you can delete them.  BTY I am still waiting for my Arduino Pro mini to try it out.
Thanks and Cheers!
