Hey guys! Sorry to dig up an older post, but I could do with some assistance wiring in a switch too and this one seems totally relevant.
I'm looking to wire in a push-to-make switch on D0 and am having the floating phenomena too. As @DJ points out, if I put my hand anywhere near the wires it sets D0 to "on" in ARC. Am I right in thinking that I should be looking at a pull-up resistor that is wired up like this? confused
By my understanding, this will mean the signal is in a high-state when the switch is open, and low-state when the switch is closed (as the current now flows to ground).
Here's how I wire bump switches to the EZB(4)
Thanks @Robot-Doc. Maybe I need to re-research pull-up and pull-down resistors then! blush Am I right to say the "+5V" on your diagram relates to the middle pin on the EZB? Also, I calculated a 5k ohm resistor so I'm assuming my maths is totally bogus? Cheers:)
Edit: ... I've just realised you stated EZB v4, sorry I should have mentioned I'm on EZB v3
I wire mine like @Robot-Doc too. Only I tend to use a 1K resister.
If you use an ADC port you could use multiple switches I believe, sort of like this.
V3 same, in fact definitely +5 on the vcc pin. On the v4 it is unregulated pass through from the input voltage.
Thanks @thetechguru and @JustinRatliff, I think I've cracked it with a 5k resistor :)
#15   — Edited
What do you use to see the value and how do you use that to control the robot?
#16
Judging by your question, perhaps you should start by Googling... "what is a robot" and go from there...
