Neopixel Ring icon Neopixel Ring — ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code. Try it →
#19
@Doc is that a seller you have used yourself? I ask because I have bought cables and some have been totally useless so now I stick to a seller I know sends good stuff.
They are what I use. Cut the wires and solder on jumper wires, cover with heat shrink (or tape if you're on a budget) and viola, you have the cable you need.
@Josh, are these the crimps you use?
I prefer to use these terminal blocks;
They do them in 3A, 5A, 15A and 30A they are also totally enclosed so no chance of something dropping on them and shorting anything.
For the common ground I like to use these;
RichThe link provided is to a seller I use, and the cables work fine. Of the ones I've used, none have been defective.
#21
@ Rich , yes that style crimp spade connectors. They never come loose and i use the barrier trip for extra protection you can spray or paint on liquid rubber and it makes the heads of the screws insulated but i just place a piece of tape over the top and all the connections are completely covered at that point. I use white tape so i can write on it with a sharpie to label what the connection so are. I did this on my fish tank controller
#22
There are silver and gold plated versions , turns out silver is more conductive but gold yells that you spent the extra money.
I just use stuff like these silver plated and insulated connectors.
Can anyone sketch up a way to do this? It needs to fit in a humanoid robot that is 17 in. tall (custom, built upon bioloid frames & dynamixel 12a's) and fit into a small backpack on the back. Help would be appreciated.
#24
Do you have the bipedal robot frame yet assembled with pics. I could draw some general ideas. Take in mind a backpack effects balance , he would need to lean forward like a hiker.
