Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
Resolved Resolved by Rich!
Help With Jd
Help with JD, JD is calibrated, fine tuned, latest ARC, and example. When he is connected, the int. starts calibrate frame, which looks ok. (all 90 degrees) see pic. The shoulders servos appear to be correct (pointing up as shown in lesson). I have read posts offset jd. When I manually lift my jd arms they only rise slightly above chest? (I think this is wrong) Do I need to offset servos that much when they are straight (as lessons shows) up during calibrate? When I hit stop (stand) His arms point back? He will walk, but back balanced. See pic. Checked wiring several times?
Has any one else received a JD recently? Maybe I am still doing something wrong? Thanks, Steve s calibrate pic
stand pic
... By the way @Rich's JD looks like he has been lifting weights.... :P
It's all that dancing he's been doing! Good for the upper body:D
@Rich No way man, with arms like that... Your JD has been doing push ups....:P
Thanks for all the quick help, I love EZ Robot and all the great community!
My wife will be happy because my little man can stand up, from sitting! Did I say I love EZ Robot. Now I have to help my grandson with his claws. Thanks, Steve S
You're welcome.
Wait, your grandson has claws? You should see a doctor about that;)
#15
@Steve... Help you grandson with his claws? Are you sure that's not the cat you're talking about?:P You don't want to get those two mixed up... Trust me:)
#16
Here is what we are giving one of grandsons for Christmas.
