NMS Navigation Data Grabber icon NMS Navigation Data Grabber — Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan. Try it →
Absolutely... Does really well with arduino and i am sure it will do just as well with a Raspberry Pi... Serial communication is one way to do it...
Thank you for responding back, but how do I do it? Because I want to have either ezb4 or tiny as the main controller and the other the driver it's an educational project.
Use the SendSerial commands on the ez-b in EZ-Script to send commands to the arduino.
Arduino requires programming. So you will need to write your program on Arduino to receive the commands
Good morning family of robots, and What I'm saying not the audrino but other micro controllers.
What other micro controllers are you talking about? Do you have the names and/or links to them?.... Any micro controller that can do serial should in theory should have no problem connecting to the EZB....
That is arduino based, as I understand.
I think what you're misunderstanding is that ALL other controllers require complicated C++ code to have them do anything.
So, if you wish for another controller to be slave communication to the ezb, you have to write that code on the other controller. The code will be specific to what you want it to do.
Why do you want to use a cm530? The ezb controllers dynamical servos natively.
With all the time I'm spending in college I've been so busy that I hardly have a chance on working both my ezb or tiny. Until now I'm doing a project and presenting it to my processor, so I want my robot to be more of an educational robot. That's why I only deal with ez robot and co., but I will try to download the plugins for my dynamixel servos.
