Ultrasonic Distance icon Ultrasonic Distance — Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output Try it →
Resolved Resolved by Rich!
Ezb3 Won't Connect
OOPS! I posted twice.
Well, I will just use this space to ask another question.
I can't find all of the resources for the EZB3. All of the help and tutorials. I found a few, but not many. Where did they go? I was very familiar with the other setup and I could find anything. Now, the GUI is nicer, but I am lost.
All roads lead to V4. That is nice, but I am still using V3 also. I may upgrade at some point. But for right now, I want to use both v3 and v4 together.
It has been so long since I hooked them up that I don't remember how.
There should be a LEGACY section that has all of the original stuff.
Thank You.
South Africa
When the old ones were here I saved it on my home screen so here is a link to the old page
Link I got my one saved under the roomba tutorial but you can select which one you want try this link to
Link
All of the controls have a ? By the X. Clicking on it will take you to the tutorial for the control.
sometimes the ? doesn't give you much help.
I would like to know if
forward (speed) would work with the sabertooth.
I need to vary the speed that it goes so Outside would not be that limited. But, in the apartment, it needs to slow down.
Thanks,
Mel
To control speed on the Sabertooth, you need to hook up the PWM ports to digital ports, and then add PWM sliders. There are two PWM ports on the sabertooth, one for each motor, so you can independently adjust the speed of each one in case your motors don't turn at exactly the same rate. For simplicity, you can connect both PWM ports to one digital port and just have one slider, but you get a little less control that way.
I have a question. If I do the PWM ports for control, do I need to hook them to the sabertooth. Or will the use the sabertooth through the program? I have a signal wire going to the sabertooth and of course the battery and M1 and M2. I would have to control both motors because I could not turn left or right if I controlled them together, I guess. You tell me. Thanks!
If you have the dips set as per DJ's tutorial...... and if using scripts, I would use the serial command...
I have another thread that I asked a similar question.
Do I unhook the sabertooth to D0. Or do I just leave the sabertooth like it is already working. But use the H-Bridge PWM Movement Panel instead of the sabertooth panel. I haven't seen d.J.'s tutorial yet. I will look for it.
sorry for being so Dense.
