EZ Chart icon EZ Chart — 4-series bar chart for real-time sensor comparison in ARC; set titles, values, RGB bar colors and conditional coloring via EZ-Script. Try it →
Ez-b Fails With I2c Script
Ez-B Fails With I2c Script
This is the first time I have tried using the I2C command and port. The EZ-B browns out (blue tooth is still blinking) when I run the command with nothing attatched at the port. Sometimes it fails right away running the script once and sometimes it takes 3 to 4 times for it to fail. No brownouts occur when not running the script!
I2CWrite(0,0x09,"n",0x00,0x00,0x11) ran Script 2
2/14/2014 3:46 PM - Comm Err: The operation has timed out. 2/14/2014 3:46 PM - BbytesToExpect: 1 2/14/2014 3:46 PM - Received: 2/14/2014 3:46 PM - Disconnected 2/14/2014 3:46 PM - Disconnected 2/14/2014 3:46 PM - Disconnected
second attempt, ran script 4 times and EZ-Board crashed.. following dbug info 2/14/2014 3:47 PM - Attempting connection on COM3 2/14/2014 3:47 PM - Connected to COM3 at 9600 2/14/2014 3:47 PM - EZ-B reports EZ-Robot OS v16 2/14/2014 3:47 PM - Welcome to EZ-B v3! 2/14/2014 3:47 PM - Connected 2/14/2014 3:47 PM - Setting battery monitor voltage: 6 2/14/2014 3:47 PM - Setting battery protection: True 2/14/2014 3:47 PM - Disgard incoming buffer (This usually means your EZ-B requires more power or the communication is unstable) 2/14/2014 3:48 PM - Comm Err: The operation has timed out. 2/14/2014 3:48 PM - BbytesToExpect: 1 2/14/2014 3:48 PM - Received: 2/14/2014 3:48 PM - Disconnected 2/14/2014 3:48 PM - Disconnected 2/14/2014 3:48 PM - Disconnected
I checked the underside of the board for any "shorting issues" at the I2C area with a magnifying glass and found none. I did take a plastic spudder probe and gently rubbed in between all 4 pins. Topside at the prcessor looked clean and free of any possible contaminates. I also, while the EZ was powered up checked voltages at the +5 volts and ground at the I2C pinouts. There was 5 volts at the SCL and SDA pinouts to ground. I dont know if that is normal?! When the EZ-Board was powered downd I measured 70K between SDA and SCL pinouts. The BlinkM type works fine on my "other" board . This is the first time I have tried using the I2C command and port. I hope someone can verify my voltage readings at the SDA and SCL points to compare my findings. I am not sure what else I can do to further trouble shoot, any ideas would be greatly appreciated:) Thanks for any assistance, Glen
I am having the same trouble! Today is the first time using the BlinkM and the I2C port and EZB keeps browning out. What can we be doing wrong? I even tried to power the BlinkM from another source and still the same thing. I don't have any trouble until I run the BlinkM script. Unlike you though I lose my blinking blue light on the board and can't get it back until it's unplugged from power and then plugged back in. Will keep working on solving the problem but just wanted you to know I'm having trouble here too.
@Herr Ball I tried the very same thing as well! " I even tried to power the BlinkM from another source and still the same thing." Have you tried testing with a volt meter on the SDA and SCL ? I am wondering if the 5 volts tested is normal or not! Also across the two , powered down, on the ohm scale.
What other peripherals are connected to the EZ-B when you are testing the BlinkM?
A few issues I have had with I2C which may guide you in the right direction (they may not though) are;
Brownouts caused by the HD servos, moving the servos on to their own supply solved this. The issue was more on the servos than I2C but it did cause some funny behaviour which is why I am mentioning it.
Connections being reversed on the SDA and SCL. This locked up the EZ-B was unresponsive until power cycling.
Loose connections/poor wiring also has caused some strange behaviour, then the SDA and SCL aren't connected or the connection drops somehow (usually through low quality wiring that open circuits) it would lock up the EZ-B and power cycling was needed.
I'd say check the connections on the SDA and SCL to the BlinkM. Check the resistance of the wiring and make sure it's low and doesn't fluctuate too much when the wiring is moved.
Also check the Vcc and Ground. The BlinkM has points on it for an external source if needed or just run Vcc and Ground from another 5V source with more current available.
I can confirm that my BlinkM has run fine plugged directly in to the I2C port, it's also worked fine when daisy chained on my LCD display. No pull up resistors are used on my I2C lines.
@DJ no other peripherals or BlinkM ..bare board! ...and sometimes it fails on the first command I2C script run and other times the third or fourth run. I am thinking there may be an issue with the board (out of warranty) If someone could check the voltages individually on the SDA and SCL to compare with my readings It will confirm or deny my suspects. :)
@irobot58
My I2C 5 volt pin is putting out the 5 volts it should. The voltage from the SDA and SCL pins are putting out 5 volts to ground also. I reread the manual and still can't figure what is going on. I have not tried any other I2C devices as I have none.
Just wanted to let you know about the voltages you ask for. Back to pulling out some more hair, something there is not a lot of anymore ... LOL.
Oh and DJ, I am not running anything else at the time of the brownout also.
@Herr Ball
Thanks for the update! Very interesting that there are two boards doing the same thing under the same circumstances. Thanks for testing the SDA and SCL leads . I hope this info helps DJ think of any further ideas to correct this issue... I am fearing the worst as it might be an internal board issue:( .....we''ll see what DJ says :) PS ....I can empathize about the pulling of hair!:) I think I might pull armpit hair instead! LOL
