Frequency Detector icon Frequency Detector — Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback. Try it →
Error Message On Scriptstop
Has anyone used ScriptStop sucessfully, without geting an Error ?
I was trying to use ScriptStop to debug my Roomba SendSerial Script, Line-By-Line, and I keep getting Syntax Error on line 18: Unknown Command: ScriptStop .
I have attached my EZ-B SendSerial Script that I am trying to learn to Debug.
Thanks All,
[email protected], 602-246-1246(H)
View thread: https://synthiam.com/Community/Questions/2747
SendSerialSound&Direction27,-Jan-2013.EZB
I've not used ScriptStop nor did I realise there was such a command, but why not test the code line by line using either the script console or by adding the label :End at the bottom of the script and using a Goto(End) where you want the script to stop?
There is no command for scriptStop. The available commands are to the right of the editor. To stop a script at a specific point, use Halt()
ScriptStop is a ControlCommand() function.
You may review examples by pressing the Examples button:)
