Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
Twitter
Electromagnet For EZB
Has anyone added an electromagnet on an EZB.  I don’t want to throw power across a coil as I don’t want to burn out EZB.
I see some arduino controller electromagnets on Amazon for $10 perhaps a skill for this in ARC?
https://www.amazon.com/KEYESTUDIO-Electric-Lifting-Solenoid-Electromagnet/dp/B09B7BQ62W
Twitter
Oh I see someone asked this before, I did not see it with a search for electromagnet.  Perhaps be nice to have a dedicated plug-in for it in ARC as I am sure a lot of people would use it.
My gripper never lines up with an object very well so I figured I would cheat and attach a small piece of steal to the top of the object and have the object line up with the gripper.
https://synthiam.com/Community/Questions/Controlling-An-Electromagnet-With-An-Ez-bv4-1512
Twitter
Thanks DJ appreciate the quick answer.  I will order one today and see how it goes.
Hi @Nink, I see you've answered your own question,:D I wanted to mention that I have used an electromagnet with the EZ-B successfully.
Yeah, you just need a transistor or MOSFET circuit to handle the current of the coil. If you had an extra H-Bridge, you could use that as well. The coil of an electromagnet can be treated as a motor or relay coil.
