Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
Resolved Resolved by Jeremie!
EZB connect to PC by USB
EZB Connect To PC By USB
Hi,
I have followed the instruction to try to connect EZB 4 to PC by USB from the link as below: https://www.ez-robot.com/learn-robotics-serial-usb-connectivity-ezb-smart-robot-controller.html
But It is not works. I guess, I bought the wrong USB adaptor (shown as below) or something wrong in connecting. So, would anyone have any suggestion for the USB? (EZB to USB adaptor, GND to GND, RX to TX, TX to RX)
https://www.amazon.ca/components-Converter-Adapter-USB-TTL-Compatible/dp/B0BQ6ZYGH8/ref=sr_1_2?crid=J9IOHKDVYC8R&keywords=USB%2Bto%2BSerial%2FTTL%2BAdapter%2B921600%2Bbaud%2Brate&qid=1695942930&sprefix=usb%2Bto%2Bserial%2Fttl%2Badapter%2B921600%2Bbaud%2Brate%2Caps%2C132&sr=8-2&th=1
Thanks in advance!
Thank you DJ, will try to find the driver to install.
Thank you Normad, nothing happen when I click it.
means no driver is there.
#11   — Edited
Oh ya! Now I remember. DJ is totally correct. The reason I couldn't get my setup to connect was because of missing windows driver for the USB adaptor. I had to go to the website of the adaptor and download the driver then install it. Windows Device Manager didn't do it automatically for me.
So this may help;
Your adaptor has the CH340 chip so you need the windows drivers for that. Here's a link to a page where you should be able to get them on the Sparkfun site. Scroll down the page to find your version needed. There is also a video there on how to install it  and how troubleshoot any problems that happen:
https://learn.sparkfun.com/tutorials/how-to-install-ch340-drivers/all#introduction
I was going by the description of your adaptor at the Amazon link you supplied. This is what is stated in the Product Description section:
Quote:
USB TTL is a Complete Plug-and-Play USB - UART interface solution developed with advanced CH340/ CP2102 chipsets.
Sorry if I gave you the wrong info.
#16
Thank you Dave! I downloaded the "CP210x Universal Windows Driver" file. Not sure the procedure that unzip the file but can't find the installer driver in the folder!
