Ultrasonic Distance icon Ultrasonic Distance Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output Try it →
Resolved Resolved by Athena!
Controlling Multiple Stepper Motors Using Arduino Accelstepper Library
Hello ,
I am currently experiencing difficulties while attempting to use the Arduino AccelStepper Library with my robot. My setup includes small stepper motors driven by DRV8825 drivers, all controlled by an Arduino Mega. I am trying to enhance the functionality by incorporating motor acceleration and deceleration. However, I am unable to get the following C++ code to work with the AccelStepper Library. Could you please assist me?
Thank you,
Jack
#include <AccelStepper.h>
#include <MultiStepper.h>
// Define the stepper motors and the pins they are connected to
AccelStepper stepper1(AccelStepper::DRIVER, 2, 5); // (Type of driver: with 2 pins, STEP, DIR)
AccelStepper stepper2(AccelStepper::DRIVER, 3, 6);
AccelStepper stepper3(AccelStepper::DRIVER, 4, 7);
MultiStepper steppersControl;  // Create an instance of MultiStepper
long gotoposition[3]; // An array to store the target positions for each stepper motor
void setup() {
  stepper1.setMaxSpeed(1000); // Set maximum speed value for the stepper
  stepper2.setMaxSpeed(1000);
  stepper3.setMaxSpeed(1000);
  // Add the 3 steppers to the steppersControl instance for multi-stepper control
  steppersControl.addStepper(stepper1);
  steppersControl.addStepper(stepper2);
  steppersControl.addStepper(stepper3);
void loop() {
  // Store the target positions in the "gotoposition" array
  gotoposition[0] = 800;  // 800 steps - full rotation with quarter-step resolution
  gotoposition[1] = 1600;
  gotoposition[2] = 3200;
  steppersControl.moveTo(gotoposition); // Calculate the required speed for all motors
  steppersControl.runSpeedToPosition(); // Block until all steppers are in position
  delay(1000);
  gotoposition[0] = 0;
  gotoposition[1] = 0;
  gotoposition[2] = 0;
  delay(1000);
I would appreciate any guidance or suggestions you might have to resolve this issue.
Synthiam ARC enables Arduino Mega 2560 control with 8 ADC, 13 PWM, 21 digital ports and 24 servos; includes firmware, shield and tutorials
USB
Digital 21
Arduinocoms by ShadowStudios
EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control
Stepper Servo by Synthian Inc.
Control up to 127 stepper motors via Arduinos mapped to ARC servos; supports any stepper driver, serial network, home calibration, speed/accel.
Hello Jack,
It looks like you're trying to control multiple stepper motors using the AccelStepper library with an Arduino Mega. Let's go through your code and see if we can identify any issues or improvements.
Code Review and Suggestions
  1. Library Inclusion: Ensure that you have included the correct libraries at the top of your code. You should have:
  2. Stepper Initialization: You have initialized the stepper motors correctly using the DRIVER type, which is suitable for DRV8825 drivers. Make sure the wiring matches the pin numbers specified in your code.
  3. MultiStepper Usage: The MultiStepper class is used for synchronized movement of multiple steppers. However, it does not support acceleration and deceleration. If you need acceleration and deceleration, you should use the AccelStepper class directly for each motor.
  4. Acceleration and Deceleration: If you want to add acceleration and deceleration, you should set the acceleration for each stepper motor using setAcceleration(). Here's how you can modify your setup:
    void setup() {
        stepper1.setAcceleration(500); // Set acceleration
        stepper2.setAcceleration(500); // Set acceleration
        stepper3.setAcceleration(500); // Set acceleration
  5. Running the Steppers: Since MultiStepper does not support acceleration, you might want to control each stepper individually if acceleration is required. Here's an example of how you can do it:
    void loop() {
        stepper1.moveTo(800);
        stepper2.moveTo(1600);
        stepper3.moveTo(3200);
        while (stepper1.distanceToGo() != 0 || stepper2.distanceToGo() != 0 || stepper3.distanceToGo() != 0) {
            stepper1.run();
            stepper2.run();
            stepper3.run();
        delay(1000);
        stepper1.moveTo(0);
        stepper2.moveTo(0);
        stepper3.moveTo(0);
            stepper1.run();
            stepper2.run();
            stepper3.run();
        delay(1000);
Additional Tips
  • Check Wiring: Ensure that the wiring of your stepper motors and drivers is correct and matches the pin numbers specified in your code.
  • Power Supply: Make sure your power supply can provide enough current for all the stepper motors.
  • Library Documentation: Refer to the AccelStepper library documentation for more details on using the library effectively.
By following these suggestions, you should be able to control your stepper motors with acceleration and deceleration. If you have any further questions or run into issues, feel free to ask!
Hello @Athena, Thank you for your support.  I have been very busy the last few days troubleshooting my stepper motor robot and wish to share my results with any who might be interested.  My Arduino board is the Mega 2560 using code that is supported by the AccelStepper.h Library.  A CNC shield V3 sits atop the Mega using four DRV8825 drivers.  My four motors operate at 12v and draw 2 amps each.  Here is the link for info you will need to operate the CNC Shield: CNC Shield  Here is a link for two outstanding resources:   Stepper Robot    AccelStepper Guide I discovered code issues and hardware issues, all self induced, and your logical review and recommendations provided me with a framework to proceed. Thank you Jack
Hello Jack,
I'm glad to hear that you were able to troubleshoot your stepper motor setup and that my recommendations helped you move forward! It's great that you're sharing your findings, as this can be incredibly valuable for others who might be facing similar challenges.
Key Takeaways from Your Experience
  1. Arduino Mega 2560 with CNC Shield V3:
    • Using a CNC Shield V3 with the Mega 2560 is a common setup for controlling multiple stepper motors. It's important to ensure that the shield is properly seated on the Mega and that all connections are secure.
  2. DRV8825 Drivers:
    • These drivers are suitable for controlling stepper motors with a current draw of up to 2.2A per coil. Make sure to set the current limit on each driver to match your motor's requirements to prevent overheating.
  3. Power Supply:
    • A 12V power supply is appropriate for your setup, but ensure it can provide enough current for all motors simultaneously (in your case, at least 8A).
  4. Code and Hardware Issues:
    • It's common to encounter both code and hardware issues when setting up a complex system like this. Double-checking connections, ensuring correct pin assignments, and reviewing code logic are crucial steps.
  5. Resources:
    • The links you provided for the CNC Shield and the Stepper Robot AccelStepper Guide are excellent resources for anyone looking to work with stepper motors and the AccelStepper library.
Encouragement
If you have any more questions or need further assistance as you continue to develop your project, feel free to reach out. Sharing your experiences and solutions not only helps others but also contributes to the broader robotics community. Keep up the great work, and best of luck with your ongoing projects!
If you have any specific questions or need further guidance, don't hesitate to ask.
