Coding Help Please
Good Morning,
I am working on a project and I need help with some code. The code I wrote monitors all 24 Digital Inputs, takes that data and places into a string value which is used to display. I then have if then statements to check for a one. I then have that output trigger the string value $FAA. If the condition is met then an email is sent out.
I guess what I am asking is if the condition is met for an email to be sent, I only need an email sent once. The code I have wrote, it will email a lot.
If any more coder with a lot more knowledge than me could take a look for me it would be appreciated.
Code posted below.
:START
#init all values
$B1T1= ""
$B1T2= ""
$B1T3= ""
$B1T4= ""
$B1T5= ""
$B1T6= ""
$B2T1= ""
$B2T2= ""
$B2T3= ""
$B2T4= ""
$B2T5= ""
$B2T6= ""
$B2T7= ""
$B3T1= ""
$B3T2= ""
$B3T3= ""
$B3T4= ""
$B3T5= ""
$B3T6= ""
$daymode = ""
$twimode = ""
$nitemode = ""
$mode = ""
$flsh = ""
:READ
#Read Inputs to get status
$B1T1 = GetDigital(D0)
sleep(10)
$B1T2 = GetDigital(D1)
sleep(10)
$B1T3 = GetDigital(D2)
sleep(10)
$B1T4 = GetDigital(D3)
sleep(10)
$B1T5 = GetDigital(D4)
sleep(10)
$B1T6 = GetDigital(D5)
sleep(10)
$B2T1 = GetDigital(D6)
sleep(10)
$B2T2 = GetDigital(D7)
sleep(10)
$B2T3 = GetDigital(D8)
sleep(10)
$B2T4 = GetDigital(D9)
sleep(10)
$B2T5 = GetDigital(D10)
sleep(10)
$B2T6 = GetDigital(D11)
sleep(10)
$B2T7 = GetDigital(D12)
sleep(10)
$B3T1 = GetDigital(D13)
sleep(10)
$B3T2 = GetDigital(D14)
sleep(10)
$B3T3 = GetDigital(D15)
sleep(10)
$B3T4 = GetDigital(D16)
sleep(10)
$B3T5 = GetDigital(D17)
sleep(10)
$B3T6 = GetDigital(D18)
sleep(10)
$daymode = GetDigital(D19)
sleep(10)
$twimode = GetDigital(D20)
sleep(10)
$nitemode = GetDigital(D21)
sleep(10)
$mode= GetDigital(D22)
sleep(10)
$flsh = GetDigital(D23)
#CONVERT 0 or 1 to pass or fail
if ($B1T1 = 0)
$B1T1D = "PASS"
elseif ($B1T1 = 1)
$B1T1D = "FAIL"
endif
if ($B1T2 = 0)
$B1T2D = "PASS"
elseif ($B1T2 = 1)
$B1T2D = "FAIL"
endif
if ($B1T3 = 0)
$B1T3D = "PASS"
elseif ($B1T3 = 1)
$B1T3D = "FAIL"
endif
if ($B1T4 = 0)
$B1T4D = "PASS"
elseif ($B1T4 = 1)
$B1T4D = "FAIL"
endif
if ($B1T5 = 0)
$B1T5D = "PASS"
elseif ($B1T5 = 1)
$B1T5D = "FAIL"
endif
if ($B1T6 = 0)
$B1T6D = "PASS"
elseif ($B1T6 = 1)
$B1T6D = "FAIL"
endif
if ($B2T1 = 0)
$B2T1D = "PASS"
elseif ($B2T1 = 1)
$B2T1D = "FAIL"
endif
if ($B2T2 = 0)
$B2T2D = "PASS"
elseif ($B2T2 = 1)
$B2T2D = "FAIL"
endif
if ($B2T3 = 0)
$B2T3D = "PASS"
elseif ($B2T3 = 1)
$B2T3D = "FAIL"
endif
if ($B2T4 = 0)
$B2T4D = "PASS"
elseif ($B2T4 = 1)
$B2T4D = "FAIL"
endif
if ($B2T5 = 0)
$B2T5D = "PASS"
elseif ($B2T5 = 1)
$B2T5D = "FAIL"
endif
if ($B2T6 = 0)
$B2T6D = "PASS"
elseif ($B2T6 = 1)
$B2T6D = "FAIL"
endif
if ($B2T7 = 0)
$B2T7D = "PASS"
elseif ($B2T7 = 1)
$B2T7D = "FAIL"
endif
if ($B3T1 = 0)
$B3T1D = "PASS"
elseif ($B3T1 = 1)
$B3T1D = "FAIL"
endif
if ($B3T2 = 0)
$B3T2D = "PASS"
elseif ($B3T2 = 1)
$B3T2D = "FAIL"
endif
if ($B3T3 = 0)
$B3T3D = "PASS"
elseif ($B3T3 = 1)
$B3T3D = "FAIL"
endif
if ($B3T4 = 0)
$B3T4D = "PASS"
elseif ($B3T4 = 1)
$B3T4D = "FAIL"
endif
if ($B3T5 = 0)
$B3T5D = "PASS"
elseif ($B3T5 = 1)
$B3T5D = "FAIL"
endif
if ($B3T6 = 0)
$B3T6D = "PASS"
elseif ($B3T6 = 1)
$B3T6D = "FAIL"
endif
if ($daymode = 1)
$daymodeD = "YES"
else
$daymodeD = ""
EndIf
if ($twimode = 1)
$twimodeD = "YES"
else
$twimodeD = ""
endif
if ($nitemode = 1)
$nitemodeD = "YES"
else
$nitemodeD = ""
endif
#WHAT TO DO IN CASE OF FAILURE
if ($B1T1 OR $B1T2 OR $B1T3 OR $B1T4 OR $B1T5 OR $B1T6= 1)
$FAA = "CALL FAA AT 1-877-487-6867"
ELSE
$FAA = ""
endif
if ($B2T1 OR $B2T2 OR $B2T3 OR $B2T4 OR $B2T5 OR $B2T6 OR $B2T7= 1)
ELSE
$FAA = ""
endif
if ($B3T1 OR $B3T2 OR $B3T3 OR $B3T4 OR $B3T5 OR $B3T6= 1)
ELSE
$FAA = ""
endif
#RUN COMMAND TO SEND EMAIL
if ($FAA = "CALL FAA AT 1-877-487-6867")
EXEC("C:\towerlights\email.bat")
else
goto(READ)
endif
To be clear - is your intention to send an email on change of digital state only?
ok i just finished a power shell script:
if ($env: Processor_Architecture -ne "x86" )  {
	write-warning 'Launching x86 PowerShell'
	&"$env:windir\syswow64\windowspowershell\v1.0\powershell.exe" -noninteractive -noprofile -file $myinvocation.Mycommand.path -executionpolicy bypass
	exit
[System.Reflection.Assembly]::LoadFile("C:\Program Files (x86)\EZ-Robot Inc\EZ-Builder\EZ_B.dll")
$ezb = New-Object -TypeName EZ_B.EZB
$ezb.Connect("192.168.18.85")
Start-Sleep -Milliseconds 500
if (-Not $ezb.IsConnected) {
	write-warning "Unable to connect to EZ-B"
$body = ""
$failures = 0
for ($p=0; $p -le 23; $p++){
	$body = $body + "Port " + $p
	if ($ezb.Digital.GetDigitalPort($p)) {
		$body = $body + " PASS"
	else {
		$body = $body + " FAIL"
		$failures = $failures + 1
	$body = $body + "`n"
$ezb.Disconnect()
if ($failures -gt 0) {
	#print the message
	$body
	$secpasswd = ConvertTo-SecureString "put-your-password-here-hopefully-no-one-will-see-it" -AsPlainText -Force
	$credentials = New-Object System.Management.Automation.PSCredential ( "[email protected] ", $secpasswd )
	$mailParam = @{
		To = "[email protected]"
		From = "[email protected]"
		Subject = "EZB Port status"
		Body = $body
		SmtpServer = "smtp.gmail.com"
		Port = 587
		Credential = $credentials
		UseSsl = 1
	Send-MailMessage @mailParam
if you want a EZScript version:
$body = ""
$failures = 0
REPEAT ($p, 0, 23, 1)
   $body = $body + "Port: " + tostring($p)
   if (GetDigital($p))
   else
   endif
   #ezscript does not support new line
   $body = $body + " ||| "
ENDREPEAT
if ($failures>0)
   #send email ...
   print($body)
endif
PS: I have changed REPEATWHILE to REPEAT is more neat! Thanks DJ:)
Here... This will trigger when the state of a digital port changes within the loop.
definearray($lastState, 24, false)
:loop
REPEAT ($cnt, 0, 23, 1)
  $v = getdigital($cnt)
  IF ($v != $lastState[$cnt])
    sayezbwait("Port " + $cnt + " to " + $v)
    $lastState[$cnt] = $v
  ENDIF
ENDREPEAT
sleep(100)
goto(loop)
@DJ and @ptp: Wow! Thank You! Give me a few years to process that code!
Here, i'll add some comments for you in the code...
What this will do is loop through all 24 digital ports and check their status. If the status of the port is different than the last time it was checked, a message will be spoken, which you can substitute for your email code. The $lastState array holds the last value of the digital port so that it doesn't keep notifying.
This code will only notify when the state of a digital port has changed.
# create an array that has 24 indexes (one for each digital port)
:loop
# Loop from 0 to 23, for each digital port
  # Get the value of the digital port
  # check if the current digital port value does not equal the last value
    # The values are different, so let's notify the admin
    # Set the last state to the current state so we do not keep sending emails on each loop
  ENDIF
ENDREPEAT
# pause for a short time to not flood the data channel
sleep(100)
goto(loop)
