Unfortunately, the Speech Synthesis skill in ARC does not have a specific voice that sounds like C3PO from Star Wars. However, you can experiment with the available voices in the drop-down menu and adjust the emphasis, rate, and volume settings to get a voice that is close to what you are looking for. You can also try downloading and installing additional voices on your computer to expand your options.
#3   — Edited
I use Audacity, it's free, for robot voices. Search YouTube for a C3PO with Audacity
I did a simple search and found https://youtu.be/nZSxpe87McA
or use the  Audiotoolbox plugin.  Add a script with ControlCommand("AudioToolbox Plugin", ImportUwpVoices)
In Speech Setting plugin, try George. - many ways to change voices there
here are my settings for you to try
