TCP Script Server Raw icon TCP Script Server Raw — TCP server for ARC accepting EZ-Script, JavaScript or Python commands, letting controllers send commands and receive line-terminated responses Try it →
C3PO Voice Synthesis Settings
Can you give me settings in the Speed Synthesis skill to get a voice close to C3PO from Star Wars?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Speech Synthesis by Synthiam
Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable.
Unfortunately, the Speech Synthesis skill in ARC does not have a specific voice that sounds like C3PO from Star Wars. However, you can experiment with the available voices in the drop-down menu and adjust the emphasis, rate, and volume settings to get a voice that is close to what you are looking for. You can also try downloading and installing additional voices on your computer to expand your options.
#3   — Edited
I use Audacity, it's free, for robot voices. Search YouTube for a C3PO with Audacity
I did a simple search and found
or use the  Audiotoolbox plugin.  Add a script with ControlCommand("AudioToolbox Plugin", ImportUwpVoices)
In Speech Setting plugin, try George. - many ways to change voices there
here are my settings for you to try
