Shortcut Creator icon Shortcut Creator Shortcut Creator relocated to the ARC Options menu; new manual page provides updated Shortcut Creator documentation. Try it →
Building Autonomous Robot For Terrain Cleanup
Mitch Torri, the owner of ASI in Mendon, Utah, generously provided my V2R_AG_Robotics 4H club with a robot project reminiscent of the Chaos Robot they developed for the military in the early 2000s. Our current robot setup includes two electric wheelchair motors, a Sabertooth 2x32 motor controller, and is operated via a FlySky remote control. We aim to expand this system to accommodate a total of eight motors of similar size.
My primary question is: How can we configure multiple Sabertooth 2x32 controllers to work harmoniously within Synthiam ARC to control and collect data from all the motors for autonomous operation? It seems impractical for a single person to manually coordinate eight motors, especially across rugged terrain. We have a challenging task ahead, as we need to manage a 30-acre steep, overgrown hillside along the downtown Ogden River in Utah. The goal is to clear and maintain this area to prevent potential fire hazards, similar to those seen in Los Angeles.
We envision deploying a swarm of these Chaos-style robots, which will communicate with overhead drones. These robots will cut through three-foot tall grass, brush, and maneuver around both standing and fallen trees.
We plan to use gas engines to initially charge the batteries, but our future goal involves developing a more efficient power supply system. With various technological advancements coming together, this project is an exciting opportunity to embrace what I refer to as 21st-century literacy.
What are your thoughts on this endeavor? Is it a bold vision or overly ambitious?
EZ-B v4/2 robot controller: dual Cortex ARM, Wi-Fi, audio/video, 24 servo/digital ports, I2C/UART, camera and Synthiam ARC control for custom robots
Sabertooth Movement Panel by Dimension Engineering
Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options.
#1   — Edited
Welcome to Synthiam. There is no limit to anything that you can do in Synthiam ARC. Could you provide more information about your design? You mentioned "how many 2x32" can be used in ARC. That answer is "unlimited". However, it would be best to post your design, schematic, or notes about the robot and how the controllers are used. Also, please provide details about what microcontroller and computer installation you are using.
Using the "Correct Grammar and Spelling" option is ideal when you post. This will help you rewrite your post to be more easily read and help you identify the meat of your question. I will run the auto-grammar on your question for you.
This would be the easiest to get up and running in a few minutes...
Add a Sabertooth Movement Panel for the drive motors. The two driver motors on each side would work in conjunction because we see no reason they should all be separate. That drive style is called "Skid Steer," much like how a bulldozer turns and moves.
  • Two Sabertooth scripts for the rotation of each track. That way, you can trigger them by joystick buttons to raise and lower each individually
  • Lastly, add the joystick robot skill to control it by one person
I would also recommend adding a camera as well.
@Athena, I think you commented on my question. "Building Autonomous robot for terrain clean up". The picture of the chaos robot show why we need 4 drive motors for each side that are independently controlled. So if can't see I will try to explain. This robot may need to spin a track one track and arm up or down while the other is doing the opposite like going over a rock or log . The tracts may go in same direction but one arm is going up while the other is going down. See if a human in your office can explain it to you by looking at the picture I included and put it into words you can follow.
#3   — Edited
Hi chucksmithut,
Thanks for providing more details about your Chaos-style robot design for terrain cleanup. It sounds like you’re working on an advanced autonomous platform where each side of your robot has four independently controlled drive motors. This independent control is crucial to navigate obstacles like rocks or logs, where one track might need to lift while the other stays lower-or even spin at a different rate to help the robot pivot around obstacles.
Below are some insights and recommendations on how you can set this up in Synthiam ARC:
1. Configuring Multiple Sabertooth Movement Panels
Multiple Controllers in ARC:
ARC limits one Movement Panel per project, but additional scripts for Sabertooths can be created. For your application, you might consider assigning each Sabertooth 2x32 controller a separate script and use the Movement Panel for moving the robot. For example, if you use two Sabertooth controllers (one per side), they could each drive two or more motors in parallel. Alternatively, if you need truly independent control of individual pairs of motors (or even individual motors). This way, you can later call their functions independently or in combination via ARC scripting.
Grouping Motors by Function:
It may be practical to group the motors that normally work in tandem-for instance, pairing two motors on one track that always share the same drive direction. This "skid steer" concept lets you combine commands so that when one Movement Panel is triggered, both motor pairs move in unison. When one track or its suspension arm needs to be independent (raising or lowering during obstacle traversal), you can override the default behavior with custom scripting.
2. Using ARC Scripting and Joystick Control
Custom Commands:
Using the ARC scripting language (JavaScript or Python), you can coordinate multiple Sabertooth Movement Panels together. For example, you might write a script that:
- Commands one Sabertooth panel to spin a track while another panel adjusts the arm position (raising or lowering)
- Monitors input from a Direct Input Joystick to dynamically assist with differential motor control. You can even designate joystick buttons not only for overall movement (forward, reverse, etc.) but also to trigger independent actions on each side.
ControlCommand():
This function lets you send messages from one robot skill to another. You might use it to, for instance, have one panel receive a "track raise" command while the other keeps driving. The key is to name your controls distinctly (e.g., "LeftDrive," "RightDrive," "LeftArm," "RightArm") so that your scripts know exactly which controller to direct.
Variable Speed and Direction:
Since terrain cleanup requires nuanced adjustments (like one track moving faster than the other or one set reversing), consider mapping your joystick’s analog inputs to control the speed of each Sabertooth panel individually using functions such as:
- Movement.setSpeedLeft(speed)
- Movement.setSpeedRight(speed)
For the Sabertooth panels, you may need to set up custom scripts that translate these values into the appropriate serial commands for each controller.
3. Additional Considerations
Wiring and Electrical Separation:
Make sure that your wiring accounts for common grounds between the EZ-B, Sabertooth controllers, and the motors-they must share a common reference voltage without causing interference. Document your schematic carefully, including how each Sabertooth connects to its dedicated independent pair (or group) of motors.
Expansion with Sensors and Camera:
Given the challenging, uneven terrain, consider incorporating sensors (or even a camera with vision tracking) so that the robot can autonomously detect obstacles and adjust its motor outputs accordingly. This extra feedback could be integrated into your SCR scripts to make real-time decisions.
Custom robot skill Development:
If the default Sabertooth Movement Panel skill doesn’t give you the granularity you need, Synthiam ARC allows you to create custom robot skills. You can write a custom skill (see the Create robot skill documentation: Creating a Robot Skill) that sends precise commands to each motor controller based on real-time sensor input or joystick commands.
4. Next Steps
  1. Documentation & Schematic:
    Share your design schematic or detailed notes with your team (or here on the Synthiam community) so that others can offer further suggestions. The more clarity you provide (including which EZ-B microcontroller you’re using in your installation), the more tailored the support.
  2. Prototype in ARC:
    Start with two Sabertooth Movement Panel skills-one for each side of the robot. Ensure their basic forward, reverse, and turning commands work in tandem. Then, incrementally add additional panels for extra independent control (for example, for the suspension arms).
  3. Scripting Custom Functions:
    Develop custom scripts that orchestrate the independent movements. Test these scripts with the Joystick (Direct Input) skill, mapping specific buttons and analog inputs to the different functions (drive, arm up/down, track spin).
Final Thoughts
Your vision for creating an autonomous robot that navigates rugged terrain with independent motor control is bold and ambitious. This is exactly the kind of challenge that ARC and Synthiam’s flexible skill and scripting setup are designed to handle. While the idea of synchronizing eight motors might seem daunting initially, breaking the task down into smaller steps (grouping drives, using multiple movement panels, and custom scripting) will make it manageable. With careful planning and phased implementation, you’ll be well on your way to building a robust autonomous solution for terrain cleanup.
If you have any further details (such as wiring diagrams or photos of your current setup) or need help scripting specific commands, feel free to ask. I’m here to help you map out the next steps!
Best regards,
Athena
Synthiam ARC Support Technician
Us humans also see your messages:)
Athena is spot on with her response. However, details about the robot microcontroller, computer, and power are useful to provide guidance.
Also, you mention controlling the robot but have not led to a method. We all assumed a joystick, as that’s a popular choice vs tablets. What options were you thinking?
It will have to be Autonomous. Training will have to be in simulation. The voice commands will be used when moving to actual on robot deployment. Remember each of the 8 motors have to operate independently. To much for a human with joy stick to operate in all the possibilities of rugged terrain operations. Is this to much for ARC? That is my question I am trying to find out. Thanks !
#6   — Edited
Of course not - what do you mean by "training will have to be in simulation"? Can you please elaborate on what your goal is? I think you will gain from reviewing the getting started guide. That will familiarize you with the terminology and the details we request to provide guidance. Having the motors operate independently is not an issue. Perhaps you can start small to familiarize yourself with the capabilities of ARC because it far exceeds your question, but you can't understand the answer if you don't understand the question:). Douglas Adams from The Hitchhiker's Guide to the Galaxy taught me that haha
#7   — Edited
I think you should start with the robot that you posted. Just choose a computer/microcontroller configuration and use the Sabertooth motor driver. That will familiarize you with making a robot with ARC. It's way easier and more powerful than you're assuming - there's a reason we modestly have over 4 million robots connected to Synthiam ARC:D. But that being said. This robot you have in the photo is an excellent place for you to start before taking down the giant.
That robot is an excellent base for which the Getting Started guide will be helpful. Here's a direct link: https://synthiam.com/Support/Get-Started/how-to-make-a-robot/make-a-diy-robot
Remember, just like making a sandwich, you'll need to build the robot's program in stages. For example, you can't throw the peanut butter on the bread while it's still in the bag!
Once you're comfortable with getting that robot going, you can tackle the giant (the 4 tracked skid steer).
Great, don't mean to bother. I just wonder if I should put the time into ARC with out having an understanding of it's limits. I have been looking at Nvidia technology and that autonomous capabilities. So I would rather not learn ARC if it was going to come up short.
Sure we can build a joystick operated ARC process for the two wheelchair motors with Sabertooth. But that is not an Autonomous trained Chaos style robot. Simulation is where we turn a URDF robot loose in a simulated rugged environment and let it figure out how to gain valuable functions. Does that make any sense?
