Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
Building A Gripper
I reached the point with my Developer Kit that I needed a gripper. So I downloaded and printed the plastic parts but then discovered that I needed a smaller servo than what was in the Kit. So I ordered a micro servo which arrived yesterday. Looks like I need to modify either the micro servo or the housing to fit the micro servo into the gripper? Any advice on what I need to modify would be appreciated!
Is the servo too small? I think ez robot might use a different servo for the claw than the mini servos sold in the store...
Need to cut the tabs off the servo.
Ahhh, ok so the claw does use the mini servos from your store then?
Thanks! Probably ought to mention that somewhere...
