Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
Brainstorming Ideas For Movable Real Ears On My Robot
I want to build ears for my robot. Brainstorming for any help or input ideas on building moveable ears for my robot? I have micro servos that can power them. I want to build her real ears, instead of the painted ears. First thought was to purchase some 3D printed ears then I thought about fabricating some aluminum ears. The size would be somewhere between the current painted ears and smaller then the Mercury Man ears? I liked the ears on Lexi. Any ideas and thoughts are welcome. I am open to any thoughts or printed ideas. Thanks, Steve S /uploads/ears-635385989095448894.jpg
Steve,
you could put a thin stick (painted), and let it move up and down on the sides of the unit. Attach whatever you want to be the ears. Get a 180 degree servo and let the stick move up and down sort of like my favorite martian.
Just my 2 cents.
I will be interested in seeing how this turns out.
Mel
Mel, Thank you for responding. I was thinking of something similar with maybe aluminum or printed. Steve S
can you use some like i-qbot ?
Nomad, I found an assembly vid of that robot and it looked good, but I was thinking more of winged style pointed ear. This forum is great and I learn so much of what is out there. Thank you, Steve S
great you found some ideas:D
