Soundboard (PC)— Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate.Try it →
You want to know if what wires in the EZ-Robot store can handle how much current? How much current do you want to push (*correction - draw) through them? How much do you think they can handle?
@JustinRatlif.... Current is drawn not pushed... Devices pull or draw current form their power source.... The amount available is based on how much the power source can deliver... Fuses protect against too much current being drawn from the power source... This also protects wiring as depending on the gauge can only handle a specific amount of current...
Here is a chart that should help.
hi rz90208
thanks for the chard.i dont have the batt harnas wire.
Patrick I don't think your link works to your wire harness. How much current do you want to run through might be a better question?
This site might help you: https://www.powerstream.com/Wire_Size.htm
hey justin
i fix the link.i have wires they are 2.5 amp.just wondering if the ones here, in store can have more current.
wire ebay
howmuch current goes thru the wire excample with an jd ?
@RichardR - Thank you for correcting my verbiage
