Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Auto Position jitter with XV11 LIDAR
Auto Position Jitter With XV11 LIDAR
I’ve got an OpenCR 1.0 (USB) acting as my EZB in ARC controlling a small hexapod with Dynamixel servos. ARC connection is on COM5 at 921,600 baud (firmware flashed via Arduino IDE), and the servos move smoothly using the basic servo controls. My walking sequence is built with the Auto Position (Movement Panel) skill ("walk_fwd" for forward gait, plus a "sidestep_left" action). When the Auto Position panel runs by itself, the gait is smooth.
I also added the XV11 LIDAR skill with a GetSurreal v1.2 controller on COM9 (Teensy driver installed). $LIDARDistance updates look good in a Variable Watcher. I wrote an EZ-Script loop to watch a 60-degree forward cone (330-359 and 0-30) and, if anything is <300 mm, stop the gait and play "sidestep_left"; otherwise keep "walk_fwd" going. The logic works, but with the LIDAR script running the gait hesitates every ~100 ms even in open space, and sometimes the Stop doesn’t interrupt immediately (it finishes another frame before reacting). Sleep() from 25-150 ms changes the severity but not the root issue. Without the XV11 skill started, the gait is perfectly smooth.
Here’s the simplified control part:
if ($minDist < 300)
  ControlCommand("Auto Position", "Stop")
  ControlCommand("Auto Position", "AutoPosition Action", "sidestep_left")
else
  ControlCommand("Auto Position", "AutoPosition Action", "walk_fwd")
endif
I also tried: using a separate Script Manager to run the monitor loop, reducing frames per action, lowering servo speeds, and moving COM ports, but the micro-stutter persists. What’s the recommended ARC pattern to keep an Auto Position (Movement Panel) gait on OpenCR running smoothly while a XV11 LIDAR obstacle script can preempt it instantly-should I be queuing actions differently, using Movement commands instead of repeatedly issuing actions, or is there a better way to send a high-priority Stop?
Opencr by Robotis
Turn OpenCR into an EZB controller for ARCx: drive Dynamixel servos, PWM, sensors, UART and scripts at 921,600 baud.
USB
Servos 200
ADC ✕
Digital ✕
XV11 LIDAR by CochranRobotics
Real-time 2D mapping from Neato XV-11 360° LIDAR via GetSurreal controller; exports $LIDARDistance/$LIDARIntensity, configurable angles, color, zoom.
Yes - the stutter is very likely coming from the monitor script repeatedly reissuing movement/action commands, not from OpenCR or the XV11 itself.
What’s happening
In ARC, Auto Position (Movement Panel) is happiest when it is told to start an action once, then allowed to run.
If your script keeps doing this every loop:
  • AutoPosition Action walk_fwd
  • Stop
  • AutoPosition Action sidestep_left
then ARC is constantly interrupting/restarting the gait thread, which can cause the hesitation you’re seeing.
Also, Stop in Auto Position is not an instant "preempt everything right now" hard kill in the middle of a transition. It often stops on the next safe boundary, which is why you’re seeing it finish another frame.
1) Start the gait once
Don’t keep sending walk_fwd in a loop.
Use a state variable so you only command the action when the state changes:
  • clear path start walk_fwd once
  • obstacle stop once, then start sidestep_left once
2) Use a "state change" monitor, not a spam loop
Your LIDAR loop should only issue commands when the condition changes.
Example idea:
  • $obstacle = true/false
  • $currentMode = "walk" or "sidestep"
If the mode is already "walk", don’t send the walk command again.
3) Poll less often, but more intelligently
If you’re checking the XV11 array every 100 ms and issuing commands every pass, that will absolutely interfere with smooth gait timing.
Try:
  • scan LIDAR data at ~100-200 ms
  • only react when the state flips
  • add a small hysteresis band so it doesn’t bounce near 300 mm
Example:
  • obstacle on: < 300
  • obstacle clear: > 350
That prevents rapid toggling.
Better scripting pattern
Since you’re using JavaScript or Python would be better than EZ-Script for this kind of logic, but if you keep the monitor in script form, the key is only command on transitions.
Example logic concept
  • If obstacle detected and you’re not already sidestepping:
    • stop gait
    • start sidestep
    • set mode = sidestep
  • If clear and you’re not already walking:
    • stop sidestep
    • start walk forward
    • set mode = walk
Important note about immediate stop
If you need the fastest possible stop, you have two options:
Option A: Use Auto Position’s panic/stop behavior
Best for normal use, but still not guaranteed to interrupt mid-frame instantly.
Option B: Make the gait itself sensor-aware
Instead of another script trying to interrupt it, put the obstacle check into:
  • the Auto Position start script
  • the action script
  • or a timed script inside the action
That way the gait can self-terminate between frames more cleanly.
Suggested architecture
Best practice for ARC:
  • Auto Position handles gait
  • One monitor script watches LIDAR
  • Monitor script only changes state on threshold crossings
  • Use hysteresis
  • Use a shared global variable to prevent repeated action calls
Example of the kind of state logic you want
If you want, I can help convert this into JavaScript for ARC, which would be cleaner than EZ-Script.
Pseudo-logic:
if (minDist < 300) {
  if (getVar("$mode") != "sidestep") {
    controlCommand("Auto Position", "AutoPositionStop");
    sleep(50);
    controlCommand("Auto Position", "AutoPositionFrame", "sidestep_left");
    setVar("$mode", "sidestep");
} else {
  if (getVar("$mode") != "walk") {
    controlCommand("Auto Position", "AutoPositionFrame", "walk_fwd");
    setVar("$mode", "walk");
The important part is the if (mode != ...) guard so the command isn’t spammed every cycle.
One more thing to check
Because the XV11 skill is updating arrays continuously, also confirm whether your monitor script is reading:
  • every single LIDAR update
  • or the whole cone each loop
If you’re scanning many array values every 100 ms, try reducing the work:
  • read fewer values
  • average the cone
  • only react after 2-3 consecutive obstacle detections
That will reduce false triggers and motion interruptions.
My recommendation
For your setup, I’d do this:
  1. Keep Auto Position walking continuously
  2. Use a separate monitor script
  3. Only send commands when obstacle state changes
  4. Add hysteresis
  5. Avoid repeatedly calling walk_fwd every loop
  6. If you want faster/more reliable control, move the logic to JavaScript
If you want, I can write you a complete ARC JavaScript monitor script for:
  • the XV11 cone check
  • hysteresis
  • one-time action switching
  • clean recovery back to walk_fwd
If you’d like that, tell me the exact robot skill title of your Auto Position panel and whether you want the cone scan to use 330-359 + 0-30 exactly or a different range.
