Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Auto Position And Ssc-32 Servo Release
I have touch on a similar subject in a previous post about using "Servo Release" using the virtual commands, to which a way of doing this has not been found.
So I thought I would try the Auto Position control today, and used the virtual ports and set up some servos connected to an SSC-32U. On the digital ports in the Auto Position control, 0 releases the servos from their holding position fine. But I found that using 0 or -1 using virtual ports still hold the servos position.
So two question.
1.) Could a "0" servo release command be added to the Auto Position control to act the same way as the digital ports?
2.) I received an email from RobotShop which said the following...
Quote:
Sending position 0 to your SSC-32U for any channel will cancel movement for that channel and also stop sending a signal (i.e.: releasing that servo motor).
For example, to stop/release a servo motor on channel #5, you would send: #5P0 <cr>.
What would be the EZ-Script command to perform the above mentioned #5P0 <cr> command using UARTWrite? (There should be no space between #5P0 and <cr> . This was done because of forum formatting).
In regards to question 2 in the post above, here's what I use to move servos with scripts which I got from RR's tutorial...
$pos = "P1450"
 $m_speed = "S700"
UARTWrite(0,0,"#1"+$pos+$m_speed,13)
I don't see how I should convert the #5P0 <cr> servo release command mentioned above in the above post to an EZ Script command like the one above.
i'll take a look at the ssc-32 control for releasing a servo
but for our ez-script, just change the code to S0 instead of S700
Okay, thanks DJ. I'll try changing the 700 to 0 as well.
@DJ.
Easy when you now how;).
Putting the zero in place of the sevo positions worked great, and does indeed release the servo. I had a feeling that's what needed to be done and thought I did that a few weeks back, but realise I thing I changed the speed by accident instead (I have a tendency of doing that recently), but after Richards warning about dropping a servos position to anything under 500 of over 2500 could potentially burn out a servo out, I was a little cautious as I only have one spare servo left, so wanted to be sure.
Anyway, many thanks. At least E4-B4 (and any future robots) will be a lot quieter now (buzz buzz).:)
Thanks again.
