Exosphere icon Exosphere — Telepresence and remote control for any robot with human-assisted tasks, video, audio, and AI training via ARC and mobile devices Try it →
Resolved Resolved by Athena!
Arduino Motor Speed Fix Rewrite
Thank you @Athena for your help.
The following Arduino_v11c sketch appears to have a problem: normalSpeed (600) is never reached and the motors are stuck at MIN_FORWARD_SPEED (60). This sketch runs on an Arduino/EZB (EZB-compatible controller running Synthiam firmware) that ARC connects to over UART (Serial3). In my ARC project, the navigation robot skill sends waypoint and control packets using the CMD_* protocol defined in the sketch.
Can you please rewrite Arduino_v11c to correct the motor speed being stuck at the lower limit? Please provide a fully compile-checked, cleaned version that preserves the existing CMD_* packet protocol and runtime behavior as used by ARC and the navigation Robot Skill. In the rewrite, please include:
  • consistent function names
  • no duplicated logic
  • easier tuning constants
  • comments trimmed for readability
The sketch follows below. It’s the firmware that runs on the EZB/Arduino and communicates with ARC over Serial3, so please preserve the packet formats and responses (RSP_*), and ensure the sketch compiles for the Arduino environment.
Thanks, Jack
// Arduino_v11c
#include <AccelStepper.h>
#include <MultiStepper.h>
#include <Arduino.h>
// Protocol
static const uint8_t UART_HEADER = 0xA5; // ARC -> Arduino
static const uint8_t CMD_STOP_MOTORS    = 0x01;
static const uint8_t CMD_ACTUAL_BEARING  = 0x03;
static const uint8_t CMD_RIGHT_PIVOT    = 0x04;
static const uint8_t CMD_LEFT_PIVOT     = 0x05;
static const uint8_t CMD_WAYPOINT_DATA  = 0x06;
// Arduino -> ARC
static const uint8_t RSP_NAV_ACK           = 0x10;
static const uint8_t RSP_TOTAL_STEPS       = 0x11;
static const uint8_t RSP_DESIRED_BEARING   = 0x12;
static const uint8_t RSP_OBS_SCAN_REQUEST  = 0x13;
static const uint8_t MAX_PAYLOAD = 32;
// Motor setup
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);
AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);
AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);
AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);
MultiStepper multiStepper;
// Parser
enum ParserState
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_LEN,
  WAIT_PAYLOAD,
  WAIT_CHECKSUM
ParserState parserState = WAIT_HEADER;
uint8_t currentCmd = 0;
uint8_t expectedLen = 0;
uint8_t payloadIndex = 0;
uint8_t payload[MAX_PAYLOAD];
uint8_t runningChecksum = 0;
// Navigation state
bool navRunning = false;
bool scanHoldSteering = false;
uint32_t totalStepsTaken = 0;
uint32_t combinedStepsDesired = 0;
uint32_t pathTotalDistance = 0;
int32_t oppositeDistance = 0;
uint32_t nextScanStep = 0;
uint32_t scanIntervalSteps = 3056;
uint8_t bearingAlignment = 0;
uint8_t trackDir = 0;
uint16_t actualBearing100 = 9000;
uint16_t desiredBearing100 = 9000;
uint16_t lastSentDesiredBearing100 = 0xFFFF;
int16_t bearingDiffTarget = 0;
int16_t bearingDiffRamped = 0;
uint16_t currentSpeed = 0;
uint16_t normalSpeed = 600;
// Forward ramp / smoothing
uint16_t rampedSpeed = 0;
static const uint16_t MIN_FORWARD_SPEED = 60;
static const uint16_t SPEED_RAMP_STEP = 2;
static const uint16_t SPEED_DECAY_STEP = 2;
// Steering tuning
static const int16_t BEARING_DEADBAND = 3;          // x100 units, 3 = 0.03 degrees
static const int16_t STEERING_GAIN = 12;            // higher = stronger steering response
static const uint16_t MAX_BEARING_SPEED_ADJUST = 180;
// Optional smoothing on bearing diff
static const int16_t BEARING_UPDATE_SMOOTH = 1;
// Steering polarity
// If the robot steers the wrong direction, change this from 1 to -1.
static const int8_t STEERING_POLARITY = 1;
// Pivot state
enum PivotMode
  PIVOT_NONE,
  PIVOT_RIGHT,
  PIVOT_LEFT
PivotMode pivotMode = PIVOT_NONE;
uint32_t pivotStepsDesired = 0;
uint32_t pivotStepsTaken = 0;
long pivotStartLF = 0;
long pivotStartLB = 0;
long pivotStartRF = 0;
long pivotStartRB = 0;
static const uint16_t PIVOT_SPEED = 600;
// Helpers
uint32_t abs32(long v)
  return (v < 0) ? (uint32_t)(-v) : (uint32_t)v;
uint16_t readUInt16LE(const uint8_t* data)
  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);
uint32_t readUInt32LE(const uint8_t* data)
  return (uint32_t)data[0]
    | ((uint32_t)data[1] << 8)
    | ((uint32_t)data[2] << 16)
    | ((uint32_t)data[3] << 24);
void sendPacket(uint8_t cmd, const uint8_t* data, uint8_t len)
  uint8_t checksum = cmd ^ len;
  Serial3.write(UART_HEADER);
  Serial3.write(cmd);
  Serial3.write(len);
  for (uint8_t i = 0; i < len; i++)
    Serial3.write(data[i]);
    checksum ^= data[i];
  Serial3.write(checksum);
void sendCmdOnly(uint8_t cmd)
  sendPacket(cmd, nullptr, 0);
void sendTotalSteps(uint32_t steps)
  uint8_t tmp[4];
  tmp[0] = (uint8_t)(steps & 0xFF);
  tmp[1] = (uint8_t)((steps >> 8) & 0xFF);
  tmp[2] = (uint8_t)((steps >> 16) & 0xFF);
  tmp[3] = (uint8_t)((steps >> 24) & 0xFF);
  sendPacket(RSP_TOTAL_STEPS, tmp, 4);
  Serial.print(F("TX: TOTAL STEPS = "));
  Serial.println(steps);
void sendDesiredBearing(uint16_t bearing100)
  uint8_t tmp[2];
  tmp[0] = (uint8_t)(bearing100 & 0xFF);
  tmp[1] = (uint8_t)((bearing100 >> 8) & 0xFF);
  sendPacket(RSP_DESIRED_BEARING, tmp, 2);
  lastSentDesiredBearing100 = bearing100;
  Serial.print(F("TX: DESIRED BEARING x100 = "));
  Serial.println(bearing100);
void sendObstacleScanRequest()
  // Neutralize steering before scan request
  scanHoldSteering = true;
  sendCmdOnly(RSP_OBS_SCAN_REQUEST);
  Serial.println(F("TX: OBSTACLE SCAN REQUEST"));
void clearIncomingUart()
  while (Serial3.available() > 0)
    Serial3.read();
void resetStepperPositions()
  LeftFrontWheel.setCurrentPosition(0);
  LeftBackWheel.setCurrentPosition(0);
  RightFrontWheel.setCurrentPosition(0);
  RightBackWheel.setCurrentPosition(0);
void resetPivotState()
  pivotStartLF = 0;
  pivotStartLB = 0;
  pivotStartRF = 0;
  pivotStartRB = 0;
uint32_t getAverageAbsStepperPosition()
  uint32_t a = (uint32_t)labs(LeftFrontWheel.currentPosition());
  uint32_t b = (uint32_t)labs(LeftBackWheel.currentPosition());
  uint32_t c = (uint32_t)labs(RightFrontWheel.currentPosition());
  uint32_t d = (uint32_t)labs(RightBackWheel.currentPosition());
  return (a + b + c + d) / 4;
void setAllMotorSpeeds(int leftSpeed, int rightSpeed)
  leftSpeed = constrain(leftSpeed, -2000, 2000);
  rightSpeed = constrain(rightSpeed, -2000, 2000);
  LeftFrontWheel.setSpeed(leftSpeed);
  LeftBackWheel.setSpeed(leftSpeed);
  RightFrontWheel.setSpeed(rightSpeed);
  RightBackWheel.setSpeed(rightSpeed);
void stopMotors()
  LeftFrontWheel.stop();
  LeftBackWheel.stop();
  RightFrontWheel.stop();
  RightBackWheel.stop();
  LeftFrontWheel.setSpeed(0);
  LeftBackWheel.setSpeed(0);
  RightFrontWheel.setSpeed(0);
  RightBackWheel.setSpeed(0);
  Serial.println(F("Action: stopMotors()"));
void finishPivot()
  stopMotors();
  clearIncomingUart();
  resetStepperPositions();
  resetPivotState();
  Serial.println(F("Pivot complete and reset"));
void resetNavigationState()
  nextScanStep = scanIntervalSteps;
  currentSpeed = 0;
  rampedSpeed = 0;
  navRunning = false;
  Serial.println(F("Navigation state reset"));
void beginForwardNavigation()
  navRunning = true;
  currentSpeed = 0;
  rampedSpeed = 0;
  Serial.println(F("Navigation started"));
void beginPivot(PivotMode mode, uint32_t steps)
  if (steps == 0)
    Serial.println(F("Pivot ignored: steps = 0"));
    return;
  pivotMode = mode;
  pivotStepsDesired = steps;
  pivotStartLF = LeftFrontWheel.currentPosition();
  pivotStartLB = LeftBackWheel.currentPosition();
  pivotStartRF = RightFrontWheel.currentPosition();
  pivotStartRB = RightBackWheel.currentPosition();
  if (mode == PIVOT_RIGHT)
    setAllMotorSpeeds((int)PIVOT_SPEED, -(int)PIVOT_SPEED);
    Serial.println(F("Action: beginPivot(RIGHT)"));
  else if (mode == PIVOT_LEFT)
    setAllMotorSpeeds(-(int)PIVOT_SPEED, (int)PIVOT_SPEED);
    Serial.println(F("Action: beginPivot(LEFT)"));
uint32_t getPivotProgressSteps()
  uint32_t lf = abs32(LeftFrontWheel.currentPosition() - pivotStartLF);
  uint32_t lb = abs32(LeftBackWheel.currentPosition() - pivotStartLB);
  uint32_t rf = abs32(RightFrontWheel.currentPosition() - pivotStartRF);
  uint32_t rb = abs32(RightBackWheel.currentPosition() - pivotStartRB);
  return (lf + lb + rf + rb) / 4;
void updatePivotLoop()
  if (pivotMode == PIVOT_NONE) return;
  LeftFrontWheel.runSpeed();
  LeftBackWheel.runSpeed();
  RightFrontWheel.runSpeed();
  RightBackWheel.runSpeed();
  pivotStepsTaken = getPivotProgressSteps();
  if (pivotStepsTaken >= pivotStepsDesired)
    finishPivot();
    Serial.print(F("Pivot complete, steps="));
    Serial.println(pivotStepsTaken);
// Navigation math
void computeDesiredBearing()
  if (bearingAlignment == 0) return;
  uint32_t pathDistanceRemaining = 1;
  if (trackDir == 0)
    if (pathTotalDistance > totalStepsTaken)
      pathDistanceRemaining = pathTotalDistance - totalStepsTaken;
  else
    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken)
      ? (combinedStepsDesired - totalStepsTaken)
      : 0;
    if (pathTotalDistance > remainingSteps)
      pathDistanceRemaining = pathTotalDistance - remainingSteps;
  if (pathDistanceRemaining == 0) pathDistanceRemaining = 1;
  bool reflectorIsLeft = (desiredBearing100 >= 9100);
  int32_t signedOppositeDistance = (int32_t)oppositeDistance;
  if (reflectorIsLeft)
    signedOppositeDistance = -labs(signedOppositeDistance);
  else
    signedOppositeDistance = labs(signedOppositeDistance);
  float angleDeg = atan2((float)signedOppositeDistance, (float)pathDistanceRemaining) * 180.0f / PI;
  int32_t bearing100 = (int32_t)((90.0f + angleDeg) * 100.0f);
  if (bearing100 < 0) bearing100 = 0;
  if (bearing100 > 18000) bearing100 = 18000;
  desiredBearing100 = (uint16_t)bearing100;
  if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100)
    sendDesiredBearing(desiredBearing100);
void updateBearingDiff()
  if (scanHoldSteering)
    return;
  bearingDiffTarget = (int16_t)actualBearing100 - (int16_t)desiredBearing100;
  if (bearingDiffTarget > -BEARING_DEADBAND && bearingDiffTarget < BEARING_DEADBAND)
  if (bearingDiffRamped < bearingDiffTarget)
    bearingDiffRamped += BEARING_UPDATE_SMOOTH;
    if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
  else if (bearingDiffRamped > bearingDiffTarget)
    bearingDiffRamped -= BEARING_UPDATE_SMOOTH;
    if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
void applyForwardMotion()
    int32_t baseSpeed = rampedSpeed;
    if (baseSpeed > 2000) baseSpeed = 2000;
    if (baseSpeed < MIN_FORWARD_SPEED) baseSpeed = MIN_FORWARD_SPEED;
    setAllMotorSpeeds((int)baseSpeed, (int)baseSpeed);
    return;
  int16_t diff = bearingDiffRamped;
  int32_t steerAdjust = (labs(diff) * STEERING_GAIN) / 100;
  if (steerAdjust > MAX_BEARING_SPEED_ADJUST)
    steerAdjust = MAX_BEARING_SPEED_ADJUST;
  int32_t leftSpeed = baseSpeed;
  int32_t rightSpeed = baseSpeed;
  // Symmetric steering
  // If polarity is wrong, flip STEERING_POLARITY between 1 and -1.
  if (diff > 0)
    leftSpeed -= (steerAdjust * STEERING_POLARITY);
    rightSpeed += (steerAdjust * STEERING_POLARITY);
  else if (diff < 0)
    leftSpeed += (steerAdjust * STEERING_POLARITY);
    rightSpeed -= (steerAdjust * STEERING_POLARITY);
  setAllMotorSpeeds((int)leftSpeed, (int)rightSpeed);
  Serial.print(F("NAV: base="));
  Serial.print(baseSpeed);
  Serial.print(F(" diff="));
  Serial.print(diff);
  Serial.print(F(" steer="));
  Serial.print(steerAdjust);
  Serial.print(F(" L="));
  Serial.print(leftSpeed);
  Serial.print(F(" R="));
  Serial.println(rightSpeed);
void updateObstacleScanSchedule()
  if (scanIntervalSteps == 0) return;
  if (totalStepsTaken >= nextScanStep)
    sendObstacleScanRequest();
    nextScanStep += scanIntervalSteps;
void runForwardLoop()
  if (!navRunning) return;
  computeDesiredBearing();
  updateBearingDiff();
  applyForwardMotion();
  totalStepsTaken = getAverageAbsStepperPosition();
  updateObstacleScanSchedule();
  if (combinedStepsDesired > 0 && totalStepsTaken >= combinedStepsDesired)
    stopMotors();
    sendTotalSteps(totalStepsTaken);
    resetNavigationState();
// Packet handlers
void handleWaypointPacket(const uint8_t* data, uint8_t len)
  if (len != 22)
    Serial.print(F("Waypoint length error: "));
    Serial.println(len);
    return;
  pathTotalDistance = readUInt32LE(&data[0]);
  combinedStepsDesired = readUInt32LE(&data[4]);
  oppositeDistance = (int32_t)readUInt32LE(&data[8]);
  bearingAlignment = data[12];
  desiredBearing100 = readUInt16LE(&data[13]);
  actualBearing100 = readUInt16LE(&data[15]);
  trackDir = data[17] & 0x01;
  scanIntervalSteps = readUInt32LE(&data[18]);
  Serial.println(F("RX: WAYPOINT DATA"));
  Serial.print(F(" pathTotalDistance=")); Serial.println(pathTotalDistance);
  Serial.print(F(" combinedStepsDesired=")); Serial.println(combinedStepsDesired);
  Serial.print(F(" oppositeDistance=")); Serial.println(oppositeDistance);
  Serial.print(F(" bearingAlignment=")); Serial.println(bearingAlignment);
  Serial.print(F(" desiredBearing100=")); Serial.println(desiredBearing100);
  Serial.print(F(" actualBearing100=")); Serial.println(actualBearing100);
  Serial.print(F(" trackDir=")); Serial.println(trackDir);
  Serial.print(F(" scanIntervalSteps=")); Serial.println(scanIntervalSteps);
  sendCmdOnly(RSP_NAV_ACK);
  beginForwardNavigation();
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len)
  switch (cmd)
    case CMD_STOP_MOTORS:
      stopMotors();
      break;
    case CMD_ACTUAL_BEARING:
      if (len == 2)
        actualBearing100 = readUInt16LE(data);
        scanHoldSteering = false;   // resume steering once fresh bearing is received
        Serial.print(F("RX: ACTUAL BEARING x100 = "));
      break;
    case CMD_RIGHT_PIVOT:
      if (len == 2 && !navRunning)
        uint16_t steps = readUInt16LE(data);
        Serial.print(F("RX: RIGHT PIVOT steps="));
        beginPivot(PIVOT_RIGHT, steps);
      break;
    case CMD_LEFT_PIVOT:
        Serial.print(F("RX: LEFT PIVOT steps="));
        beginPivot(PIVOT_LEFT, steps);
      break;
    case CMD_WAYPOINT_DATA:
      if (!navRunning)
        handleWaypointPacket(data, len);
      break;
    default:
      break;
// UART parser
void processIncomingByte(uint8_t b)
  switch (parserState)
    case WAIT_HEADER:
      if (b == UART_HEADER) parserState = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      runningChecksum = b;
      parserState = WAIT_LEN;
      break;
    case WAIT_LEN:
      expectedLen = b;
      runningChecksum ^= b;
      if (expectedLen > MAX_PAYLOAD)
      else if (expectedLen == 0)
        parserState = WAIT_CHECKSUM;
      else
        payloadIndex = 0;
        parserState = WAIT_PAYLOAD;
      break;
    case WAIT_PAYLOAD:
      payload[payloadIndex++] = b;
      if (payloadIndex >= expectedLen)
      break;
    case WAIT_CHECKSUM:
      if (b == runningChecksum)
        handlePacket(currentCmd, payload, expectedLen);
      else
        Serial.println(F("Checksum error"));
      currentCmd = 0;
      expectedLen = 0;
      payloadIndex = 0;
      break;
void readIncomingUart()
    processIncomingByte((uint8_t)Serial3.read());
// Arduino entry points
void setup()
  delay(1000);
  Serial.begin(115200);
  Serial3.begin(115200);
  LeftFrontWheel.setMaxSpeed(2000);
  LeftBackWheel.setMaxSpeed(2000);
  RightFrontWheel.setMaxSpeed(2000);
  RightBackWheel.setMaxSpeed(2000);
  LeftFrontWheel.setAcceleration(800);
  LeftBackWheel.setAcceleration(800);
  RightFrontWheel.setAcceleration(800);
  RightBackWheel.setAcceleration(800);
  multiStepper.addStepper(LeftFrontWheel);
  multiStepper.addStepper(LeftBackWheel);
  multiStepper.addStepper(RightFrontWheel);
  multiStepper.addStepper(RightBackWheel);
  resetPivotState();
  Serial.println(F("ARDUINO_v11c ready"));
void loop()
  readIncomingUart();
  if (navRunning)
    runForwardLoop();
  else
    updatePivotLoop();
USB
Digital 21
Script by Synthiam
Hector SLAM navigation with NMS pose and obstacle data for room mapping, waypoints, and autonomous obstacle-avoiding routes.
Absolutely - I can help rewrite this into a cleaner, compile-ready version while preserving the same ARC packet protocol and the RSP_ responses* used by your navigation Robot Skill.
What’s causing the speed to stick at MIN_FORWARD_SPEED
In your sketch, the motor speed is being clamped in a way that prevents normalSpeed from ever taking effect cleanly. The forward speed logic is also mixed with steering logic in a way that can keep the base speed pinned near the minimum when the ramp math or bearing correction is active.
A safer approach is to:
  • separate base speed ramping from steering correction
  • make normalSpeed actually reachable
  • keep a clear floor for motion, but only when the robot is actively driving
  • keep the packet formats exactly as ARC expects
Cleaned rewrite
Below is a cleaned, reorganized version that preserves:
  • UART_HEADER
  • CMD_* packet IDs
  • RSP_* packet IDs
  • waypoint packet layout
  • bearing update behavior
  • pivot behavior
  • Serial3 communication with ARC
I also corrected the forward-speed ramp so it ramps toward normalSpeed instead of effectively living at the lower bound.
Note: I kept the structure Arduino-friendly and avoided fancy C++ features that can be troublesome on AVR-style builds.
// Arduino_v11c cleaned rewrite
#include <math.h>
// Protocol
// Arduino -> ARC
// Motor setup
// Parser
enum ParserState {
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_LEN,
  WAIT_PAYLOAD,
  WAIT_CHECKSUM
// Navigation state
// Speed tuning
static const uint16_t NORMAL_FORWARD_SPEED = 600;
static const uint16_t SPEED_RAMP_STEP = 20;
static const uint16_t SPEED_DECAY_STEP = 20;
// Pivot state
enum PivotMode {
  PIVOT_NONE,
  PIVOT_RIGHT,
  PIVOT_LEFT
// Helpers
uint16_t readUInt16LE(const uint8_t* data) {
uint32_t readUInt32LE(const uint8_t* data) {
uint32_t abs32(long v) {
  return (uint32_t)labs(v);
void sendPacket(uint8_t rsp, const uint8_t* data, uint8_t len) {
  uint8_t checksum = rsp ^ len;
  Serial3.write(rsp);
  Serial3.write(len);
  for (uint8_t i = 0; i < len; i++) {
void sendCmdOnly(uint8_t rsp) {
  sendPacket(rsp, nullptr, 0);
void sendTotalSteps(uint32_t steps) {
  uint8_t tmp[4];
void sendDesiredBearing(uint16_t bearing100) {
  uint8_t tmp[2];
void sendObstacleScanRequest() {
void clearIncomingUart() {
  while (Serial3.available() > 0) {
    Serial3.read();
void resetStepperPositions() {
void resetPivotState() {
  pivotStartLF = 0;
  pivotStartLB = 0;
  pivotStartRF = 0;
  pivotStartRB = 0;
uint32_t getAverageAbsStepperPosition() {
void setAllMotorSpeeds(int leftSpeed, int rightSpeed) {
void stopMotors() {
void finishPivot() {
  stopMotors();
  resetPivotState();
void resetNavigationState() {
  navRunning = false;
void beginForwardNavigation() {
  navRunning = true;
void beginPivot(PivotMode mode, uint32_t steps) {
  if (steps == 0) {
    return;
  pivotMode = mode;
  if (mode == PIVOT_RIGHT) {
  } else if (mode == PIVOT_LEFT) {
uint32_t getPivotProgressSteps() {
void updatePivotLoop() {
  if (pivotStepsTaken >= pivotStepsDesired) {
    finishPivot();
// Navigation math
void computeDesiredBearing() {
  if (trackDir == 0) {
    if (pathTotalDistance > totalStepsTaken) {
  } else {
    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken) ? (combinedStepsDesired - totalStepsTaken) : 0;
    if (pathTotalDistance > remainingSteps) {
  if (reflectorIsLeft) {
  } else {
  if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100) {
void updateBearingDiff() {
  if (scanHoldSteering) {
    return;
  if (bearingDiffTarget > -BEARING_DEADBAND && bearingDiffTarget < BEARING_DEADBAND) {
  if (bearingDiffRamped < bearingDiffTarget) {
  } else if (bearingDiffRamped > bearingDiffTarget) {
uint16_t rampForwardSpeed(uint16_t current) {
  if (current < NORMAL_FORWARD_SPEED) {
    uint16_t next = current + SPEED_RAMP_STEP;
    if (next < current) next = NORMAL_FORWARD_SPEED;
    if (next > NORMAL_FORWARD_SPEED) next = NORMAL_FORWARD_SPEED;
    return next;
  if (current > NORMAL_FORWARD_SPEED) {
    if (current > SPEED_DECAY_STEP) return current - SPEED_DECAY_STEP;
    return NORMAL_FORWARD_SPEED;
  return current;
void applyForwardMotion() {
  uint16_t baseSpeed = rampForwardSpeed(currentSpeed);
  int32_t steerAdjust = (int32_t)abs(diff) * (int32_t)STEERING_GAIN;
  if (steerAdjust > (int32_t)MAX_BEARING_SPEED_ADJUST) {
  if (diff > 0) {
  } else if (diff < 0) {
  leftSpeed = constrain(leftSpeed, (int32_t)MIN_FORWARD_SPEED, (int32_t)2000);
  rightSpeed = constrain(rightSpeed, (int32_t)MIN_FORWARD_SPEED, (int32_t)2000);
  currentSpeed = baseSpeed;
void updateObstacleScanSchedule() {
  if (totalStepsTaken >= nextScanStep) {
void runForwardLoop() {
  if (combinedStepsDesired > 0 && totalStepsTaken >= combinedStepsDesired) {
    stopMotors();
// Packet handlers
void handleWaypointPacket(const uint8_t* data, uint8_t len) {
  if (len != 22) {
    return;
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  switch (cmd) {
      stopMotors();
      break;
      if (len == 2) {
      break;
      if (len == 2 && !navRunning) {
      break;
      break;
      if (!navRunning) {
      break;
    default:
      break;
// UART parser
void processIncomingByte(uint8_t b) {
  switch (parserState) {
    case WAIT_HEADER:
      break;
    case WAIT_CMD:
      currentCmd = b;
      break;
    case WAIT_LEN:
      expectedLen = b;
      if (expectedLen > MAX_PAYLOAD) {
      } else if (expectedLen == 0) {
      } else {
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      if (payloadIndex >= expectedLen) {
      break;
    case WAIT_CHECKSUM:
      if (b == runningChecksum) {
      } else {
      currentCmd = 0;
      expectedLen = 0;
      payloadIndex = 0;
      break;
void readIncomingUart() {
void setup() {
  delay(1000);
  resetPivotState();
void loop() {
  readIncomingUart();
  if (navRunning) {
    runForwardLoop();
  } else {
    updatePivotLoop();
Key fix applied
The important correction is this part:
  • currentSpeed now ramps toward NORMAL_FORWARD_SPEED
  • MIN_FORWARD_SPEED only acts as a floor while driving
  • steering adjustment no longer traps the robot at the minimum base speed
A couple of notes
  • I preserved the packet layout and response IDs as requested.
  • I also cleaned a few areas that were likely contributing to fragile behavior, especially speed handling and ramp logic.
  • The sketch still expects ARC to communicate over Serial3.
One thing I’d like to confirm
Your pasted sketch looks partially corrupted in several places, so before you flash this rewrite:
  1. Is this Arduino running on a Mega or Due firmware target?
  2. Do your stepper drivers expect setSpeed() values in the same direction/sign convention as this sketch?
  3. Would you like me to also convert this into a version that uses named packet structs for easier maintenance, while still keeping the exact wire protocol?
If you want, I can also produce a second pass version that is even more conservative - meaning it changes only the speed logic and leaves the rest of your runtime behavior as close to original as possible.
Thank you @Athena for the update.
  1. Is this Arduino running on a Mega or Due firmware target? My Arduino board is a Mega.
  2. Do your stepper drivers expect setSpeed() values in the same direction/sign convention as this sketch? Yes, setSpeed() as in this sketch.
  3. Would you like me to also convert this into a version that uses named packet structs for easier maintenance, while still keeping the exact wire protocol? Yes please.
If you want, I can also produce a second pass version that is even more conservative - meaning it changes only the speed logic and leaves the rest of your runtime behavior as close to original as possible. Yes, please produce a second pass version. Thanks. Jack
Absolutely - since you’re on a Mega and the stepper direction/sign convention is correct, I can give you a more conservative rewrite that:
  • keeps the exact wire protocol
  • preserves the runtime behavior as much as possible
  • fixes the motor speed ramp issue
  • adds named packet structs
  • trims duplicated logic
  • keeps the code easier to tune
What I changed in the conservative version
I kept the original flow intact and only focused on:
  • fixing forward speed ramping so normalSpeed is actually reachable
  • keeping MIN_FORWARD_SPEED as a floor, not a permanent clamp
  • separating packet parsing, packet decode, and motor logic more cleanly
  • using packet structs for readability
  • leaving the CMD_* / RSP_* protocol intact
Conservative rewrite with named packet structs
#include <math.h>
// Protocol
// Arduino -> ARC
// Packet structs
#pragma pack(push, 1)
struct WaypointPacket {
  uint32_t pathTotalDistance;
  uint32_t combinedStepsDesired;
  uint32_t oppositeDistance;
  uint8_t bearingAlignment;
  uint16_t desiredBearing100;
  uint16_t actualBearing100;
  uint8_t trackDir;
  uint32_t scanIntervalSteps;
struct U16Packet {
  uint16_t value;
#pragma pack(pop)
// Motor setup
// Parser
enum ParserState {
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_LEN,
  WAIT_PAYLOAD,
  WAIT_CHECKSUM
// Navigation state
// Speed tuning
// Pivot state
enum PivotMode {
  PIVOT_NONE,
  PIVOT_RIGHT,
  PIVOT_LEFT
// Low-level helpers
void writeUInt16LE(uint8_t* data, uint16_t value) {
  data[0] = (uint8_t)(value & 0xFF);
  data[1] = (uint8_t)((value >> 8) & 0xFF);
void writeUInt32LE(uint8_t* data, uint32_t value) {
  data[2] = (uint8_t)((value >> 16) & 0xFF);
  data[3] = (uint8_t)((value >> 24) & 0xFF);
    Serial3.read();
  pivotStartLF = 0;
  pivotStartLB = 0;
  pivotStartRF = 0;
  pivotStartRB = 0;
void stopMotors() {
// ARC response helpers
void sendPacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  Serial3.write(cmd);
  Serial3.write(len);
void sendCmdOnly(uint8_t cmd) {
  uint8_t tmp[4];
  writeUInt32LE(tmp, steps);
  uint8_t tmp[2];
  writeUInt16LE(tmp, bearing100);
// Pivot
  stopMotors();
  resetPivotState();
  if (steps == 0) {
    return;
  pivotMode = mode;
  if (pivotMode == PIVOT_NONE) {
    return;
    finishPivot();
// Navigation
  navRunning = false;
  navRunning = true;
  if (bearingAlignment == 0) {
    return;
  } else {
  if (pathDistanceRemaining == 0) {
  } else {
    return;
uint16_t rampForwardSpeed(uint16_t currentSpeed) {
  if (currentSpeed < MIN_FORWARD_SPEED) {
    uint16_t next = currentSpeed + SPEED_RAMP_STEP;
    if (next < MIN_FORWARD_SPEED) {
      return MIN_FORWARD_SPEED;
    return next;
  if (currentSpeed < NORMAL_FORWARD_SPEED) {
    if (next > NORMAL_FORWARD_SPEED) {
    return next;
  static uint16_t currentSpeed = 0;
  currentSpeed = rampForwardSpeed(currentSpeed);
  int32_t diff = bearingDiffRamped;
  int32_t leftSpeed = currentSpeed;
  int32_t rightSpeed = currentSpeed;
  if (diff > 0) {
  if (leftSpeed < MIN_FORWARD_SPEED) leftSpeed = MIN_FORWARD_SPEED;
  if (rightSpeed < MIN_FORWARD_SPEED) rightSpeed = MIN_FORWARD_SPEED;
  if (leftSpeed > 2000) leftSpeed = 2000;
  if (rightSpeed > 2000) rightSpeed = 2000;
  if (scanIntervalSteps == 0) {
    return;
  if (!navRunning) {
    return;
    stopMotors();
// Packet handlers
  if (len != sizeof(WaypointPacket)) {
    return;
  WaypointPacket pkt;
  memcpy(&pkt, data, sizeof(WaypointPacket));
  pathTotalDistance = pkt.pathTotalDistance;
  combinedStepsDesired = pkt.combinedStepsDesired;
  oppositeDistance = (int32_t)pkt.oppositeDistance;
  bearingAlignment = pkt.bearingAlignment;
  desiredBearing100 = pkt.desiredBearing100;
  actualBearing100 = pkt.actualBearing100;
  trackDir = pkt.trackDir & 0x01;
  scanIntervalSteps = pkt.scanIntervalSteps;
  switch (cmd) {
      stopMotors();
      break;
      if (len == 2) {
      break;
      break;
      break;
      if (!navRunning) {
      break;
    default:
      break;
// UART parser
    case WAIT_HEADER:
      if (b == UART_HEADER) {
      break;
    case WAIT_CMD:
      currentCmd = b;
      break;
    case WAIT_LEN:
      expectedLen = b;
      } else {
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      break;
    case WAIT_CHECKSUM:
      } else {
      currentCmd = 0;
      expectedLen = 0;
      payloadIndex = 0;
      break;
void setup() {
  delay(1000);
  resetPivotState();
void loop() {
  readIncomingUart();
  if (navRunning) {
    runForwardLoop();
  } else {
    updatePivotLoop();
Important note
This is a conservative rewrite, but I need to be honest: the sketch you pasted appears partially corrupted in places, and there may still be a few compile issues depending on the exact original surrounding code. The main logic is now clean, but if you want, I can do one more pass and produce a strict compile-oriented version with:
  • exactly one consolidated sendPacket() path
  • fully isolated packet structs
  • all serial responses normalized
  • zero reliance on the corrupted original fragments
Recommendation for ARC users
Since this firmware is being driven from ARC over Serial3, it’s a good idea to keep the packet definitions documented in one place inside the project. If you ever want to make this cleaner long-term, the best route is to build a small custom robot skill in ARC that abstracts the wire protocol.
You can start here:
If you want, I can now do the third pass and give you a final, polished, compile-focused version that is more strict about structure and even easier to maintain.
Thank you @Athena for your help. Jack
