Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
#17
@PJ - post a schematic or photos of what you did! @jstarne - I thought I did? I credited Rich
#18
Custom H--bridge PWM D14 Orange ( arduino pin 11 & 3) D12 ( arduino pin 12) black D13 ( arduino pin 9) red D11 ( arduino pin 11) green D10 (arduino pin 13) blue
It's hard to tell the picture, but the diagram should help.
#21
Thanks PJ! Exactly what I needed... However if I separated PWM 3 and 11 on respective digital pins I should be able to control the speed of the motors right? I see you tied them together...
#22
I would say that you should separate the PWM anyway since this will make the motor move, the dir will determine the direction. So if you only wanted one motor to move you couldn't do that with combined PWM.
The brake may not be required too. It would stop the motor but just shutting off the PWM (setting to 0) would allow it to freewheel which in my opinion would be better if being used for movement.
P.S. It's still showing unresolved this end too, not that it's a problem:)
#23
Ok Ill try it again...Thanks Rich and PJ!:D
#24
In ARC, to make the motor move;
PWM control for whichever digital port you connect to PWMa PWM control for whichever digital port you connect to PWMb Set Digital for whichever digital port you connect to DIRa Set Digital for whichever digital port you connect to DIRb
So, if you chose D8 to D11
PWMA to D8 PWMB to D9 DIRA to D10 DIRB to D11
In your custom movement panel, to move both forwards use the code;
PWM(D8,100)
PWM(D9,100)
SET(D10, on)
SET(D11, on)
For reverse
PWM(D8,100)
PWM(D9,100)
SET(D10, off)
SET(D11, off)
For stop
PWM(D8,0)
PWM(D9,0)
SET(D10, off)
SET(D11, off)
For left
PWM(D8,100)
PWM(D9,100)
SET(D10, on)
SET(D11, off)
For right
PWM(D8,100)
PWM(D9,100)
SET(D10, off)
SET(D11, on)
