Animation With ARC
Hey guys, I just wanted to know if anyone has info on some stuff that I am trying to sort out here...:)
So I would like to do some correctly timed animation with my robot, my plan is to script the animation frame by frame...so it will be done with an EZ-Script rather than inside of the Auto Position Control.
So I init the servo speed first... For the animation I repeat to set my servo position followed by a pause of 33.3333333333ms because I will be animating 30fps.
So my question would be how servo speed affects the servo movement. I eyeballed that notching the speed up once will double the amount of time it takes for the servo to reach a certain position...am I right?
Does it make any sense to use slower servo speed...does it make the servo go smoother, or should I just run the animation with the speed settings kept zero?
Sundays on ARC, my kind of fun!:P
This is exactly what I was looking for...The tutorials are structured great, don't know why I missed it!
Thanks a lot @DJSures :)
