i cant seems to ad a movement to script movement panel?
Forward( 255,5000 ) sleep(1000) ControlCommand("Auto Position", AutoPositionAction, "Armwalk")
anyone thank you
Midi Control
— MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes.
anyone thank you
dj thank you again. blush
i asked you a question lol - show me the code you put into the script movement control
ah didn see that. i try pwm(D0,90) but it dont work?
ah i see the pwm change to 89 percent whits is correct. the bar in the H-bridge dont move
I can’t help unless you post the code of the script movement control
You cannot use pwm() and expect the speed to change. You set the speed and the pwm will change. The speed controls the pwm or what ever kind of speed the Movement Panel uses.
Use the speed() and let the Movement Panel do its own thing. Don’t override it
dj
sorry i dont understand coding.do you have an excample?
Why don't you use blockly? It sets the speed for you.
any coding is diff for me.but i will see if i can notest something in blockly.
