Personality Forge icon Personality Forge — Adds a Personality Forge chatbot to ARC, giving memory, emotions, AIScript dialogue, persistent conversation IDs and speech/chat integration via API. Try it →
ADC Graph spikes on Mega
ADC Graph Spikes On Mega
I’m using an Arduino Mega 2560 over USB with ARC to log an analog Sharp GP2Y0A21 distance sensor on A0 while two micro servos run a pan/tilt on ARC servo ports D0 and D1 (which map to Mega pins 22 and 23). In ARC I added the ADC Graph skill, set Board = 0 and ADC0 = A0, and I’m powering the sensor from the Mega’s 5V. When the servos are idle, ADC Graph shows a fairly steady 45-80 range (which matches ~0.9-1.5V on my multimeter), but as soon as the servos move, the ADC Graph spikes to 255 or briefly drops to near 0 every few hundred ms.
What I’ve tried so far:
  • Separate 5V BEC for the servos, sensor on Mega 5V, with common ground between BEC and Mega.
  • Added 0.1 F ceramic + 22 F electrolytic right at the sensor’s Vcc/GND, and twisted the sensor leads, routed away from servo wires.
  • Slowed ADC Graph sampling interval from default to 200 ms and then 500 ms; spikes remain.
  • Verified the sensor voltage stays relatively steady with a meter even during servo motion, so the 255 excursions look like sampling noise/ground bounce.
  • Simple averaging in ARC JavaScript seems to tame it numerically (printed to console), e.g.:
a = 0; for (i=0; i<20; i++) { a += getADC(0); Sleep(5); } print('avg=' + Math.round(a/20));
Questions:
  • Is there anything specific about ARC’s Arduino Mega ADC handling (0-255 mapping, reference, timing) that makes it sensitive to servo activity?
  • Is there a recommended RC input filter (e.g., series 1k + 0.1 F to ground) or grounding scheme for analog sensors when using ARC with a Mega?
  • Can ADC Graph apply averaging/oversampling, or is the best practice to script a smoothed value and visualize it another way?
What’s the recommended wiring and ARC-side configuration to get clean, non-saturating ADC Graph readings from this Sharp sensor on a Mega when the servos on D0/D1 are moving?
USB
Digital 21
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
ADC Graph by Synthiam
Historical ADC graph and numeric readout (0-255) for 0-3.3/5V inputs; configurable board/port, sample interval, color, and pause for ezb controllers.
Yes - what you’re seeing is very consistent with power/ground noise or ADC sampling noise caused by the servos moving, not the Sharp sensor itself.
A few key points for ARC + Arduino Mega firmware:
What ARC is doing
  • ADC0 on the Mega is read as a value from 0-255 in ARC.
  • That’s a scaled representation of the Mega’s analog reading, not a special filtered mode.
  • ADC Graph does not average/filter the signal for you - it displays the raw ADC value it receives.
So if the servo movement is injecting noise onto the analog reference, sensor ground, or 5V rail, ARC will faithfully show those spikes.
Why the spikes happen even with a multimeter
A multimeter averages over time, so it can miss very short transient dips/spikes. Your sensor may look stable on the meter but still be producing:
  • brief ground bounce
  • 5V sag
  • ADC reference noise
  • EMI from servo wiring/current surges
Those can easily push the sampled ADC reading to 0 or 255 for a moment.
1) Keep servo power separate
You already did the right thing here:
  • Servos on a separate BEC/supply
  • Common ground between BEC and Mega
That’s correct.
2) Improve grounding layout
For the cleanest analog reading:
  • Run sensor ground directly back to the Mega ground
  • Run servo ground directly back to the BEC ground
  • Tie the grounds together at a single star point
  • Avoid daisy-chaining the sensor ground through servo current paths
This is often the biggest fix.
3) Add a small RC filter on the sensor output
Yes, a small input filter is commonly used for noisy analog sensors.
A good starting point:
  • 1 k series resistor from sensor output to A0
  • 0.1 F capacitor from A0 to GND
That creates a simple low-pass filter to blunt short spikes.
If the reading becomes too sluggish, reduce the capacitor value or resistor slightly.
4) Decouple the sensor locally
You already added caps on Vcc/GND, which is good. I’d keep:
  • 0.1 F ceramic
  • 10-47 F electrolytic near the sensor
5) Keep analog wiring short and away from servo power lines
Even twisted pair helps, but also:
  • avoid running analog wire parallel to servo leads
  • don’t bundle sensor signal with PWM/servo power wiring
ARC-side recommendation
ADC Graph
ADC Graph is fine for monitoring, but it is raw input only. It does not have built-in smoothing/oversampling controls.
Best practice
Use a script to read ADC repeatedly, average it, and then:
  • log it
  • publish it as a variable
  • use it for logic
If you want a display, you can create a script-driven visualization instead of relying only on ADC Graph.
Your averaging idea is exactly the right direction
A simple moving average in ARC JavaScript is a good fix.
Here’s a cleaner version:
var sum = 0;
var samples = 20;
for (var i = 0; i < samples; i++) {
  sum += ADC.get(ADC0);
  sleep(5);
var avg = Math.round(sum / samples);
print("avg=" + avg);
setVar("$SharpFiltered", avg);
If you want, you can use that variable in other ARC skills or scripts.
If you want even better smoothing
Try:
  • 10 samples for responsive behavior
  • 20-30 samples for heavy smoothing
You can also do a median filter or reject impossible jumps, which helps with occasional servo-induced spikes.
Example simple spike rejection:
var value = ADC.get(ADC0);
var last = parseInt(getVar("$SharpLast", value));
var filtered = value;
if (Math.abs(value - last) > 80) {
  filtered = last;
setVar("$SharpLast", filtered);
print("filtered=" + filtered);
Important note about servo ports
On the Arduino Mega firmware in ARC, servo ports like D0 and D1 map to Mega pins 22 and 23, as you noted. That part is fine.
The issue isn’t the servo ports themselves - it’s usually the high current switching noise when the servos move.
My recommendation order
Try these in this order:
  1. Star ground the sensor and servo supplies
  2. Add 1 k + 0.1 F RC filter on A0
  3. Keep sensor wiring short and separated from servo wiring
  4. Use a scripted average for readings instead of raw ADC Graph for logic
  5. If needed, use a median or spike-rejection filter
ARC configuration suggestion
  • ADC Graph: keep it for live monitoring
  • Script: read ADC0, average it, and use the filtered value
  • Sampling: 200-500 ms is fine for display, but the script can sample faster if needed
Useful reference
If you want, I can write you a JavaScript filter script for ARC that:
  • averages the Sharp sensor,
  • rejects servo-caused spikes,
  • and updates a global variable you can use in other skills.
