EZMQTT Broker icon EZMQTT Broker — Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients. Try it →
A Note On Ez-ai/rafiki
A Note On Ez-Ai/Rafiki
EZ-AI development is on hold right now, well kind of...
We are in the process of working with some services that will allow the capabilities of EZ-AI to be far better than what they currently are. These include Wolfram|Alpha and IBM BlueMix/Watson. Speech Recognition will be performed through Nuance Cloud services. Advanced vision features will be available through OpenCV. A quick search of these services will allow you to see the end goal of what we are doing. These will be in the Rafiki project which is the primary focus at this time for CochranRobotics. We will release a limited use version for free which will replace EZ-AI. All of the current features of the EZ-AI database will be available through the new version. All of the services provided by EZ-AI will be available through REST queries and exposed services. This will allow plugins to ARC to be able to use these services.
There has been a huge amount of changes to what is possible since I first started working on EZ-AI. This huge shift of improved technologies has made it necessary to rework EZ-AI so that it can continue to grow and mature.
We are also toying with the idea of allowing programmers to write their own business logic layer within Rafiki. This would allow a programmer to be able to use the core services of Rafiki/EZ-AI and write their own applications with the data that is returned. It will probably be a while before this is implemented, but it is something that we are trying to make happen.
I have probably said too much, but wanted to give you all a picture of what is happening and why EZ-AI isn't being worked on directly. We hope to have our new AI available around the end of the year. There are multiple developers working on this while I find come up with solutions to other problems that arise.
As far as Rafiki goes, the pods are functioning great and additional code/abilities are being added almost daily. The models for the pods are being tweaked to expose the HDMI and usb ports and network port to the outside of the case. This will allow someone to connect a mouse, keyboard and monitor to the pod and use it as a computer if they would like. The Rafiki Bot is about 1/3 of the way printed. I am making modifications to the models as needed and reprinting some of the parts as needed. There will be 6 subsystems on this robot. 3 of these subsystems have been written and are ready to use. The other 3 subsystems cant be worked on until more of the Rafiki Bot has been printed. The 3 that are not complete are all very similar for motor control. I hope to have these ready in a couple of weeks. I should be able to show a demo of the Rafiki Bot in about a month, and then all of the robot programming starts. I will work on the charger base shortly after the robot has been completed and the pods are all working with all of their functionality.
One more thing on EZ-AI... As a part of this rewrite, you will just need to have Java installed on your computer to install and use EZ-AI. The days of the huge install will be behind us so it should make it far better in the long run. The other thing that this allows is robot platform independence. I will be working on modules in ARC to allow the features of EZ-AI to be accessible far more easily. This will probably not be worked on until December at the earliest.
Okay, going back to my robot cave. Have a great day all.
where does the name rafiki comes from?
#98
It is Swahili for Friend.
There are some reasons that I chose it above this though. The son of mine that is helping to program some things, when he was a young child, we would watch "Lion King" over and over. Rafiki was a wise character in this movie. Also, there was a tree in the movie that was important. In math, there are a lot of different tree's used to demonstrate relationships to things. This is used because of the branches that a tree has and the branches that the are in math. We have something special planned for the tree with Rafiki.
great thinking.i never saw the lion king,maybe i chould see it. am curious to see what you have planned.
#100
Thanks for the update David. Looking forward to EZ AI updates! I'm full into production on Gaurdians 2 so not much I can do in my apartment on weekends. By looking forward to playing with the plug in when available.
As a note, I printed some large parts for the BB8 and never used pla, always abs. Now I'll never use abs again, no warping or split layers .
#101
Yea, just wish PLA would bond as strong as ABS without the mess of epoxy. I make huge messes with epoxy...
BTW, our online store is... NOW OPEN!
There are only a few items available for purchase though and it looks rough. I will be updating it with more as the week goes along.
#102
I print both... I don't have any problems printing with ABS... It depends on your printer, settings and size of print... PLA is definitely easier to print, but if you leave anything printed in PLA in the sun or anywhere hot it will melt on you. ABS is awesome for strength, longevity and as David pointed out bonding... acetone bonds abs stronger than the actual part is...
#103
When building things big and have multiple intersecting pieces I find ABS warps to much even on heated bed in an enclosure. Assembling the parts leaves gaps and parts that don't connect easily. My personal experience. I'm sure there are many factors , the filament manufacture , the settings and machine that affect the outcome.
#104
I was looking at many of the body parts. I was wondering if I lay them down and use support to the build plate, will I have less problems with separation and warping ? , than standing them up? They will be needing sanding anyway. I also assume the robot needs a skim coat of bondo for finish anyway.
