Sherpa-ONNX Speech To Text icon Sherpa-ONNX Speech To Text — Offline continuous speech recognition with wake word support, custom phrases, and real-time transcription using sherpa-onnx models on ARC Windows. Try it →
A Note On Ez-ai/rafiki
A Note On Ez-Ai/Rafiki
EZ-AI development is on hold right now, well kind of...
We are in the process of working with some services that will allow the capabilities of EZ-AI to be far better than what they currently are. These include Wolfram|Alpha and IBM BlueMix/Watson. Speech Recognition will be performed through Nuance Cloud services. Advanced vision features will be available through OpenCV. A quick search of these services will allow you to see the end goal of what we are doing. These will be in the Rafiki project which is the primary focus at this time for CochranRobotics. We will release a limited use version for free which will replace EZ-AI. All of the current features of the EZ-AI database will be available through the new version. All of the services provided by EZ-AI will be available through REST queries and exposed services. This will allow plugins to ARC to be able to use these services.
There has been a huge amount of changes to what is possible since I first started working on EZ-AI. This huge shift of improved technologies has made it necessary to rework EZ-AI so that it can continue to grow and mature.
We are also toying with the idea of allowing programmers to write their own business logic layer within Rafiki. This would allow a programmer to be able to use the core services of Rafiki/EZ-AI and write their own applications with the data that is returned. It will probably be a while before this is implemented, but it is something that we are trying to make happen.
I have probably said too much, but wanted to give you all a picture of what is happening and why EZ-AI isn't being worked on directly. We hope to have our new AI available around the end of the year. There are multiple developers working on this while I find come up with solutions to other problems that arise.
As far as Rafiki goes, the pods are functioning great and additional code/abilities are being added almost daily. The models for the pods are being tweaked to expose the HDMI and usb ports and network port to the outside of the case. This will allow someone to connect a mouse, keyboard and monitor to the pod and use it as a computer if they would like. The Rafiki Bot is about 1/3 of the way printed. I am making modifications to the models as needed and reprinting some of the parts as needed. There will be 6 subsystems on this robot. 3 of these subsystems have been written and are ready to use. The other 3 subsystems cant be worked on until more of the Rafiki Bot has been printed. The 3 that are not complete are all very similar for motor control. I hope to have these ready in a couple of weeks. I should be able to show a demo of the Rafiki Bot in about a month, and then all of the robot programming starts. I will work on the charger base shortly after the robot has been completed and the pods are all working with all of their functionality.
One more thing on EZ-AI... As a part of this rewrite, you will just need to have Java installed on your computer to install and use EZ-AI. The days of the huge install will be behind us so it should make it far better in the long run. The other thing that this allows is robot platform independence. I will be working on modules in ARC to allow the features of EZ-AI to be accessible far more easily. This will probably not be worked on until December at the earliest.
Okay, going back to my robot cave. Have a great day all.
#113
Simplified my website a lot. There isn't a message board right now. I don't know if I will add it back in as it was rarely used. Also, no login required, but if you want to register, you can. The information is now a bit limited on the site, but my goal is to keep the site just to what it needs to have on it. It is easier to manage and maintain and is more like the current layout of most websites. I will add more to it as needed, but this is where today's time went.
In the store, we only ship in the US, Canada and Mexico right now. Shipping overseas is very expensive and I haven't researched the other possibilities for doing this. Sending a small box to England using UPS costs $86+ USD. Until I find a better shipping solution, or need to find a better shipping solution, I am not going to be selling items overseas.
Let me know what you think of the new layout. Thanks David
Clean layout, sometimes simple & less is the best approach.
#115
Thanks ptp. There is a lot behind the scenes. I have tied in Google Apps for my company communication stuff like Email, Calendar, Groups and Storage. It is nice to be able to go to one place for all of this. It makes a geographically dispersed company much easier to manage.
Simple is good. I just wasted a day to get simple done and really didn't want to spend a ton of time on it.
#116
@David, I like the new look on your web site!
#118
Hi Dave, Will you be marking .stl file updates with rev notations ? I have begun printing the base .stl files and want to make sure I have the latest versions, if changes are made.
Ron
#119
Will do. All of the base is complete that you have except for part 17. There is a small change that I will get updated for download in the github repository and in the google drive share.
Thanks David
#120
On the first layer of the shell there are a couple of modifications to 2 parts (under the wing) that I wont publish until I get a chance to print them out and verify that they work as expected. I will be adding access holes with the second layer of the shell that will be in the area that is covered by the wings. the covers for these holes will be held in place by the top and bottom sections of the shell and will use magnets to hold these covers in place. Until I can print these sections I would advise against printing the shell. Hopefully this week I will have that redesign completed.
