Custom Movement Panel icon Custom Movement Panel — Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors Try it →
usb connection, no ezb camera is one or the other.
You can always use the laptop's camera or another usb camera since your EZB is attached to your computer anyway...
Is it possible to run two EZB's and then have the USB attached to one and a camera attached to the other EZB?
Yes, but the other ez-b would be connected over wifi, which someone trying to use USB would probably be trying to avoid.
OK, but I also thought you could connect one or more ezb to a master ezb over WiFi. Then could the master ezb connect with USB?
No master role.
Each EZB appear as independent controller with a single connection:
  1. Wifi / unique IP OR
  2. Serial/USB connected to Camera Port / unique serial port
Thanks everyone, I was hoping for an answer that we could use both. Am already committed to using ezb cameras for my Inmoov.
Does anyone know if there is an adapter to connect the ezb camera to us it connected to a USB port? If I can then I will be able to connect the exbv4's to USB.
Can you connect the ezb camera to a USB to Serial/TTL Adapter?
Thanks, merne
Not possible
