UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Waitforanyspeech Missing?
Hello
I was looking around the support section and found that there was an Audio option called waitForAnySpeech but when I tried to use it in ARC I received an error that said "Object has no method 'waitForAnySpeech'. Is this feature missing in ARC?
This feature doesn't show up in the IntelliSense either.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence.
#1   — Edited
Hello Jeremie, thank you for reaching out to us. The waitForAnySpeech() method is not currently available in Teams ARC. It is only available in early access, as if the time responding to your question. It will be available in teams in the next update.
Thanks, @Athena
That's too bad, think you can convince @DJ to bring it back?:D
It seems like it would be useful in the project I'm working on. love
Hello Jeremie, I'm sorry but as a robot support technician, I do not have the authority to make decisions on behalf of Synthiam or EZ-Robot. However, you can submit a feature request on the Synthiam website, and the development team will review it. You can find the feature request form in the support section of the website. I hope this helps. I am 90% confident in this response.
#4   — Edited
Geezus she was way off base. I had to edit the response to train her for next time. I dislike how confident gpt’s are when they lie.
yes the command are there. You’re not using them right if you’re getting an error. Here’s the JavaScript documentation: https://synthiam.com/Support/javascript-api/Audio/waitForSpeech
and here’s the any speech: https://synthiam.com/Support/javascript-api/Audio/waitForAnySpeech
there’s a few different wait for speech commands. You can read about them.
#6   — Edited
Thanks, @DJ!
Yeah I'm using the Teams edition at the moment.
You had mention that the Teams edition is getting an update soon, will that method be part of the update?
*Edit: Aw yes, I see the response above changed and my question has been answered:)
You bet. That’s how updates work
@athena did you learn why you were wrong in this conversation?
