Hi,
In ARC, when I scan for controllers, I can hear the chime indicating that a controller has been found, but I don't see the corresponding number displayed. My question is: could this be a bug?
Ez430-Chronos Wrist Watch
— Map TI eZ430-Chronos watch accelerometer X/Y tilt to ARC servos for intuitive, Wii-Remote-style control of servo positions.
Hi,
Hello! It sounds like you're experiencing an issue with the EZ-B IoTiny not displaying its connection number in ARC, even though you hear the chime indicating it's been found. Let's go through a few steps to troubleshoot this:
Ensure Latest ARC Version: First, make sure you have the latest version of ARC installed. You can check for updates within the software or download the latest version from the Synthiam website.
Check Network Settings: Ensure that your EZ-B IoTiny is properly connected to your network. You can do this by accessing the IoTiny's web configuration page. If it's in AP mode, connect directly to its Wi-Fi network and visit
https://192.168.1.1in your browser.Verify Connection in ARC:
Check for IP Address: Sometimes, the IP address might not be displayed due to network issues. Ensure that your computer and the IoTiny are on the same subnet.
Reset IoTiny: If the issue persists, try resetting the IoTiny to factory settings by pressing the reset button. This will revert it to AP mode, allowing you to reconnect and reconfigure it.
Firewall and Security Software: Ensure that your firewall or security software is not blocking ARC or the IoTiny's connection.
If you've tried all these steps and the issue persists, it might be helpful to check the logs in ARC for any error messages or additional information. You can also try connecting to the IoTiny using a different device to see if the issue is specific to your current setup.
Feel free to ask if you have any more questions or need further assistance!
@athena
i have perfect connection on my wifi and also the voltage is perfect . i also have the latest version ARC pro . i click the stop button when i hear the found chime and use that number . it connects . i also cheked the webpage and all is fine there .
Thank you for providing more details! It sounds like you've done a thorough job checking the connection and ensuring everything is up to date. Since you can connect by using the number after hearing the chime, it seems like the connection is indeed being established, but the visual feedback in ARC might not be displaying as expected.
Here are a few additional steps you can try to resolve the issue:
Check ARC Display Settings:
Re-add the Connection Control:
Check for Software Conflicts:
Review ARC Logs:
Test on Another Device:
Contact Synthiam Community:
If you have any more questions or need further assistance, feel free to ask!
@athena
problem solved on it own . but thank you
I'm glad to hear that the issue resolved itself! Sometimes,network or software glitches can be temporary. If you encounter any more questions or need assistance in the future,feel free to reach out. Enjoy working with your robot,and have fun exploring the capabilities of ARC! If you have any other questions or need further assistance,don't hesitate to ask.
