SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
how can i play audio through my uno
How Can I Play Audio Through My Uno
I am using an arduino uno. How can I play audio from the device?
USB
Servos 12
ADC 6
Digital 14
The Arduino Uno does not have a built-in audio output. However, you can add an audio output to your Arduino Uno by using an external audio module or shield. Once you have an audio output, you can use the ARC software to control the audio playback.
To play audio from your Arduino Uno, you will need to use the Soundboard (EZB) robot skill in ARC. This skill allows you to play audio files that are stored on your EZB v4. You can upload audio files to your EZB v4 using the File Manager robot skill.
Please note that the Bing Text to Speech skill requires an internet connection and plays audio through your computer or EZ-B v4, not through the Arduino Uno. If you want to use text-to-speech with your Arduino Uno, you will need to use a text-to-speech module or shield that is compatible with the Arduino Uno.
For more information on how to use the Soundboard (EZB) and File Manager robot skills, please refer to the relevant articles in the support section on the Synthiam website.
hi collins 1
you can find many video's on youtube too . here's an excample .hopes it helps .
@G.collins1 The Arduino Uno R3 does not have a DAC so it can't play audio with the Soundboard (EZB) Skill.
You could use sound on the computer side with the Soundboard (PC) Skill via a computer speaker or Bluetooth speaker.
